What about a hard drive storage system that works with HDMI instead of firewire? at DVinfo.net
Topics about HD production.
Old June 10th, 2007, 01:01 AM   #1
I was thing. I have never seen a device like the focus hard drive storage device that works with HDMI instead of firewire. I don't even know if it is possible. But if it is, wouldn't you get better resolution, full 1920x1080 and 4:2:2 color production.
If they got black magic design to make the firmware and incorporate HDMI into the focus enhancement design, this may work. Just thought I'd share the thought.
Paul Watkins is offline   Reply With Quote
Old June 10th, 2007, 03:09 AM   #2
I guess it's possible, but it would have to be a fast system to record uncompressed hd. Plus, storage would be severely hindered. I don't know if it would be practicle if it only could record an half hour or so of footage. Maybe the future will bring a Focus-like terabyte drive that accepts HDMI. Of course, I think they would develop something like the Focus system that records HD-SDI before HDMI. That would be something, though. I wonder what the cost would be?
John Bosco Jr. is offline   Reply With Quote
Old June 10th, 2007, 03:50 AM   #3
I guess like you, John that it is possible, but highly impractical. You would require a sustained write transfer rate of around 200 MB/s, which means with current disk speeds at least a 4 or 5 disk Raid0 array of 3.5 inch 7200 RPM SATA2 disks. 2.5 inch or smaller form factors are way too slow. So volume, cooling and weight will be a major practical problem, apart from the power supply needed to run a 4 disk array. Then add to the equation that even when using 250 GB disks, so you have effectively 1TB in the array, it will only suffice for around 90 minutes to fill up all the space. So, when shooting outdoors, you have to bring at least 2 or more of these arrays for the day.
Further take into consideration the limited length of HDMI cables and the flimsy connection and you are almost required to mount it on camera. That will add at least 10 pounds in weight to the camera, including the power supply.
Last point is price. If you look at the price of the current FS-100, with storage capacity of 100 GB, at $ 1.895, can you imagine what a 1 TB array with embedded raid controller and portable power supply with loader must cost. My guess is it would be at or above the Wafian range, so at least $ 17K.
Look here: http://www.wafian.com/HR-F1.htm
BTW, can you imagine mounting a disk array like that on your A1/V1/Z1 hand held camera?
Old June 10th, 2007, 05:43 AM   #4
Take a look at this post about the "RIO ONE" portable HDMI computer by Stephen Armour. I'm sure it is still in development phase, but at least someone thinks it's feasible.
http://www.dvinfo.net/conf/showthread.php?t=92385
If enough people show interest, perhaps the development will accelerate?
I think a key aspect is that it is intended to use compression, but a more lossless format with higher bit depth. I believe Cineform is the planned software. Imagine Cineform files generated from the HDMI signal instead of the HDV and you can appreciate that it would be a huge leap in quality. Wouldn't that be something like 100mbps from an uncompressed source? That would be just dandy for compositing and the like.
Old June 10th, 2007, 08:30 AM   #5
As an alternative, I'd like to see a front end that allows you to simply attach any hard-drive or memory card. Focus already has the ability to do this, but they require you to buy their overpriced drives.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old June 10th, 2007, 09:47 AM   #6
That will not allow uncompressed 4:2:2 ingest.
Harm Millaard is offline   Reply
