Procoder 3:Problem on Playback of wmv(audio) at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old February 1st, 2008, 09:47 AM   #1
I have started using Procoder 3 to convert avi files to wmv for streaming video for our website. When I play it back in the WM player it plays fine, but if I move the scroll bar, the audio cuts out and I have to replay it to get audio again. Any thoughts?
Charles O. Volm is offline   Reply With Quote
Old February 2nd, 2008, 03:34 AM   #2
Not being an expert on the subject, this sounds more like a RAM or cpu power issue. Apart from that maybe encoding settings. Try encoding to a smaller, lighter file and see what happens.
Themis Gyparis is offline   Reply With Quote
Old February 4th, 2008, 08:33 AM   #3
Procoder 3:Problem on Playback of wmv(audio) - solved
I did an interesting thing - I tried playing it on another PC and it played fine. The WM player must have a glitch in it or something. THX
Old February 4th, 2008, 08:39 AM   #4
charles,
what version is your media player? did you download its upgrade? WM10 is ok.
Ted
Old February 5th, 2008, 09:34 AM   #5
Funny thing-- both WM Players are version 9 with identical settings. One works, the other doesn't.
Old February 5th, 2008, 10:32 AM   #6
Charles,
WM player sometimes will use codecs installed by other software. For instance, in one of my PCs i installed digisuite avi codec for their mjpeg files. The wm player will play this avi file while on a pc without this codec the wmp will not recognise this file.
Ted
Ted Ramasola is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
