Editing HD Offline at DVinfo.net
Old November 25th, 2003, 11:16 AM   #1
Editing HD Offline
I currently able to edit HD in FCP by creating a program stream using a method similar to the the one Paul Mogg mentions in this forum.
It still is a bit sluggish and long to render. It seems like there should be a way to create a stand in for the program stream, do all the editing and then switch the resource as a last step (not a new idea of course offlineRT does the same thing).
For a first step take the program stream and use FCP to export to a format Final Cut more readily handles.
Any ideas what codec I should use? I think is still needs to be 1280x720 but it can be highly compressed, I am not worried about the quality of the footage while I am editing.
Paul St. Denis is offline   Reply With Quote
Old December 2nd, 2003, 10:19 AM   #2
RED Code Chef
I heard good things about the Animation codec. But why not give
several codecs a try and report your findings here? As you say,
qaulity isn't important.
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
