A free and easy way to export Quicktime to JVC HD cameras or D-VHS - Page 5 at DVinfo.net
Old February 5th, 2004, 03:41 PM   #61
Just to let you know that I had previously tested with both Pixlet and DC30 footage and had no problems here.
Cheers
Paul
Paul Mogg is offline   Reply With Quote
Old February 6th, 2004, 10:51 AM   #62
Well.....
It output about 16 minutes before suddenly the camera stoppec.
Paul, It might be that the data rate varries. I know CineForm requires the output to be set to fixed in the Adobe MPEG encoder.
Is there a way to do that in your script?
Keep going, we're almost there!
DBK
Darren Kelly
Darren Kelly is offline   Reply With Quote
Old February 6th, 2004, 12:26 PM   #63
Paul has been kind enough also to help find a solution for encoding the uncompressed cinewave HD codec in 1080i. After tweeking Paul's scriptlet a little, I was able to get output, however, the picture was partially split. I then tried an export to pixlet first and everything went well, as did Paul's attempt. I don't know why the Cinewave codec is not allowing for a clean encode, but I thought I would pass on our experiences so far.
Thanks again to Paul.
Dave Cox is offline   Reply With Quote
Old February 12th, 2004, 01:10 PM   #64
I'm new to all this, but I was able to get Paul's program to work. It's great. I was wondering if there might be a similar solution for converting the originally captured material into pixlet. Right now, I have so many steps to accomplish before I can start editing. If there were a similar droplet to get started we'd really be set.
Thomas Ferlauto is offline   Reply With Quote
Old March 5th, 2004, 06:39 AM   #65
SD to HD?
So with this method one could edit in Final Cut Pro SD and upconvert using the JVC HD or D-VHS?
Craig Moreschini is offline   Reply With Quote
Old March 5th, 2004, 06:41 AM   #66
Re: SD to HD?
I'm looking for a temporary cheap method for converting and mixing some privious SD footage with JVC HD. So I'm looking for a method to convert SD to HD.
<<<-- Originally posted by Craig Moreschini : So with this method one could edit in Final Cut Pro SD and upconvert using the JVC HD or D-VHS? -->>>
Old March 5th, 2004, 07:26 AM   #67
This thread describes a method for exporting back to the camera, there are several methods for importing JVC's MPEG2 HD into Final Cut. Do a search for "Project X" or "Diva" in this forum to find these. I see from other posts that you are using Avid? I have zero experience with Avid at this point, but in Final Cut you can combine HD and SD footage without a problem.
Paul St. Denis is offline   Reply With Quote
Old March 8th, 2004, 10:53 PM   #68
Wow! I'm impressed. I hadn't check on this board for a while and I'm very impressed with what you've been doing Paul...
So I tried the droplet and the first step seems to process any QT file at 1280 X 720 unless the files contain audio. Whenever audio is on the QT file (regardless the format), I get this error:
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: bad header magic!
Any ideas?
Frederic Lumiere is offline   Reply With Quote
Old March 12th, 2004, 04:08 PM   #69
Hi Frederic,
Are you using HDVerter (Not HDQT2TS which is an earlier version)?
http://www.celt.sunysb.edu/paul/HDVerter.tar.gz
If so, what format is the audio you are using?
By the way, will lumeireHDV's editing solution support export?
Old March 12th, 2004, 04:15 PM   #70
Paul,
Yes, I am using the latest droplet.
I've tried many audio formats and the problem persists.
Lumiere HD will support export (we are still working out the technical hurdles).
Here's a feature list for Lumiere HD:
http://www.lumieremedia.com/hdv/lumierehd_features.pdf
Thanks, Paul.
