Top 10 Reasons to Buy Matrox MXO2 Mini – Not Intensity Pro - Page 2 at DVinfo.net
Old May 31st, 2009, 04:45 AM   #16
Thanks Gary, I thought this would be a nice little extra if it was possible and would eliminate the need for separate audio I/O for this task. Realtime cross conversion and capture at this price is pretty attractive to say the least, add h.264 acceleration and it really looks like a must for me.
Adrian Frearson is offline   Reply With Quote
Old June 17th, 2009, 03:06 PM   #17
Does anyone know where I can download a short clip recorded on a PC in the I-frame only MPEG2 mode of the MX02 mini? I'd like to test it out its files with some various NLEs before I commit to buying it.
John
John Cline is offline   Reply With Quote
Old June 18th, 2009, 11:45 AM   #18
Sponsor: Electronic Mailbox
John,
The RTX2 already uses this for analog HD capture for Premiere. No complaints about the quality. I don;t think Matrox MPEG2 HD works in any other NLE besides Premiere.
Gary
Check out http://www.videoguys.com 800 323-2325 We are the video editing and live video production experts! DV InfoNet members save 5%! Use Coupon Code DVINFO5OFF
Gary Bettan is offline   Reply With Quote
Old June 18th, 2009, 03:12 PM   #19
Gary,
I understand the the MX02 mini is only fully integrated into Premiere on the PC side. I have and use Premiere CS4, Avid Media Composer v3.5 and Vegas v9 and I much prefer Vegas. I'd like to see if Vegas can handle the MX02's I-frame-only MPEG2 files.
John
Old June 18th, 2009, 06:44 PM   #20
IF the codec is on the PC maybe Vegas and Edius will use and work with Matrox MPEG. I too am interested but would want it to work with Edius or Vegas or preferably both.
Ron Evans
Old June 22nd, 2009, 10:43 AM   #21
Originally Posted by Gary Bettan View Post
John,
I don't think Matrox MPEG2 HD works in any other NLE besides Premiere.
Gary
If it wasn't for my concern that I would be buying into a proprietary codec/wrapper, my order would already be in.
This thread illustrates some of the problems:
Matrox MXO User Forum :: View topic - MXO2 Mini and Matrox HDV
Given how video is often archived, a codec/wrapper/format without an assured long, long lifetime is simply a no-go for me.
Bill Koehler is offline   Reply With Quote
Old June 22nd, 2009, 10:48 AM   #22
Images: 10
Why is this solution better than AJA's IO Express? I know the MXO2 mini is cheaper, but, the IO Express has HD-SDI I/O.
Edit: AJA seems to exclusively be a MAC shop, the IO Express records to Apples Prores codec. But, There is a decoder available for Prores on the PC, and, hopefully the Cineform DI can also be ported to the IO Express.
Old June 22nd, 2009, 10:50 AM   #23
I can certainly understand your concern. We have good news on the Cineform front. Things are moving forward nicely and we hope to have an official announcement from Matrox & Cineform shortly.
Things not going as smooth with Sony. There is work to be done to make Vegas & Mini compatible. Not sure Sony has the resources available at the current time.
Gary
Old June 22nd, 2009, 11:27 AM   #24
Thanks for the reference, I didn't know about the IO Express, only the IO HD.
I'll bet I'm not the only one.
When I went to AJA's website and looked around, they mention PC support - and that's it. No details. They do mention the codecs that are supported only on the Mac. I didn't find anything about the ones supported on the PC or even minimum PC system requirements. The documentation is still overwhelmingly Apple/Mac centric. And the same Final Cut/Premiere Pro bias.
Old June 25th, 2009, 02:46 PM   #25
6. Matrox MXO2 Mini supports RGB as well as YUV output via HDMI and component for compatibility with a wider range of monitors – Intensity Pro provides only YUV output.
** Is this user selectable, or does the Mini automatically decide?
8. Matrox MXO2 Mini turns your HDMI screen into a professional-grade video monitor with Matrox’s unique color calibration tool. Controls for hue, chroma, contrast, brightness, and blue-only are provided. You get accurate color representation so that you can use your HDMI monitor even for color grading – Intensity Pro does not have a calibration tool.
** Reasoning to my previous question above....to utilize the HP Dreamcolor LP2480zx monitor, the monitor needs to be fed a RGB progressive signal (in order to take full advantage of all the benefits the monitor provides) which would be great if the Mini truly did this!!
10. On the PC, Matrox MXO2 Mini lets you capture to the highly-efficient Matrox MPEG-2 I-frame codec at adjustable date rates up to 300 Mbps to optimize quality and storage usage – Intensity Pro uses an older M-JPEG codec that is limited to 128 Mbps and is not user adjustable.
** Is this the only option to capture to? Can one capture the camera's native codec? What about the Mac side? Can one capture using ProRes / ProRes HQ?
12. A version of Matrox MXO2 Mini is available with Matrox MAX technology for faster than realtime H.264 HD file creation – Intensity Pro does not offer this important benefit.
** This is cool...but I'm a bit confused; does one need the CompressHD card to do this....or is MAX built into the Mini?
Andrew Clark is offline   Reply With Quote
Old June 25th, 2009, 02:53 PM   #26
I have not tested Mini with dreamcast monitor, but I do know of folks successfully using the MXO2 HDMI output with it.
MXO2 Mini is available witht he MAX option integrated into it for $849. So you don;t need the seperate compressHD card.
MAtrox MPEG-2 capture is for Premeire. Capture into Cineform is on the way. The MXO2 Mini captures directly into ProRes in real time on a quad core Mac
Gary
Old June 25th, 2009, 03:30 PM   #27
Don´t want to rain on the parade, but Intensity captures uncompressed.
I take that every day over any codec.
Also Intensity can be connected to a laptop via card slot.
In case you have to be independend of AC power....
But usualy, with all the lights and whatnot at a set, one more cable for a small PC doesn´t matter.
My ct 2
Frank
Frank Brodkorb is offline   Reply With Quote
Old June 25th, 2009, 04:50 PM   #28
Of course the MXO2 Mini captures uncompressed. I was answering specific questions about the compression options.
As for portability and versatility, MXO2 mini wins hands down. It's an I/O box, that attaches via Express Card for Laptops or PCIe card for desktop. It comes with your choice, but for $100 more you can get both! Now just move the box between your laptop and desktop!
Gary
Old June 26th, 2009, 12:27 PM   #29
Gary - Thanks for the replies...much appreciate it!! Right to the point, exactly what I needed to know.
Do you have these in stock...(with the MAX option)?
Old June 26th, 2009, 03:29 PM   #30
MXO2 mini and Mini Max are selling strong and we've got more units rolling to us from Matrox.
Not sure if we still have stock today, but more coming Mon or Tues
Gary
