Anyone here built thier own Cyclorama? Advice? - Page 2 at DVinfo.net
Home, Away From Home
Old February 7th, 2010, 09:31 AM   #16
Originally Posted by David Ruhland View Post
Thanks everyone.... this is a real pain in the *ss! but im documenting it with photos and video for ya!
Got interested in your project, David, and found this: Home_Page - Pictures could be a help for you.
/peter
Peter Erfurt is offline   Reply With Quote
Old February 8th, 2010, 01:15 AM   #17
Back when I was building my studio I contemplated a curved cyc.
My conclusion is that everything about them is relatively simple EXCEPT the corner cove.
Streight walls with a simple curve can be created out of a lot of stuff. But when you get to framing the curve of the corner cove, you're trying to cut stuff towards what you might call a multiple vanishing point mess.
If I was going to go ahead, I'd probably start with one of the commercial corner pieces, stick that at the wall junction, then just frame the simple curves from there.
I think anything else and you'll end up doing a LOT of plaster sculpting in order to get the corner cove even.
I eventually dropped the idea and left the walls as is because I've had about 50 to 1 calls to recreate an office or other room shape - verses needing a seamless cove curl. And when I need that I just use seamless paper and roll it up afterwards.
Such is life.
Bill Davis is offline   Reply
