Suggestions... at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old March 5th, 2013, 05:05 PM   #1
Suggestions...
Just wondering if anyone can advice me on the best way to mount a small 4ft crane that weigh about 8 pounds. I have a manfrotto tripod (16lbs capacity) with a 501 HDV head and a heavy duty light stand. I'd like to use the light stand however The 3/8 male thread on top of the light stand is too short to lock the crane to..i already went to a photo store and they suggested replacing the top piece with fabricated piece from a metal shop...
2nd option is to drill a bigger hole from a spare 501 quick release plate we have lying around but not sure it this can handle all the weight...the crane will be equipped with a DSLR + 14mm lens (2.7 lbs together) and about 10 lbs counter weight...any advice would be appreciated. Thanks!
Kren
Modern Wedding Cinema for the Modern Bride
www.verticalvideoworks.ca
Kren Barnes is offline   Reply With Quote
Old March 10th, 2013, 07:55 PM   #2
Re: Suggestions...
Gear Contact
i bought that jib for about $370USD, carbon fibre, super light weight, even lighter than my Manfrotto 055 carbon. but they are not taking order at this moment. you can send them a message and ask about availability
Thomas Wong is offline   Reply With Quote
Old March 10th, 2013, 09:06 PM   #3
Re: Suggestions...
I have a 4 foot jib. You can read about the setup here. http://www.dvinfo.net/forum/jibs-cra...-thoughts.html
I now have a feisol panning base mounted between the tripod and the quick release plate that is not shown in the photos. FEISOL Panning Base PB-70
Mark Williams is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
