How to carry Jib Weights on... at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old November 7th, 2006, 11:23 AM   #1
when I am air travelling how should I carry the Jib weights They are around 85Pounds of weight. I have been mostly road travelling so i lug them around but soon in Dec I will be having a multi city air travel so ... How should I carry them along with me. No i would be having facility to get weights locally so i must carry them along. Pl suggest what should be done !!!!
THX
Cheers !
Bankim Jain is offline   Reply With Quote
Old November 7th, 2006, 02:54 PM   #2
I think you are going to run into airline luggage weight restrictions and have to pay for the extra weight. You should check with the airline(s) to find out what their policy is/are.
The first solution, if you are using standard bar-bell weights, would be to purchase the weights on location -- they are not that expesnive etc.
Next solution would be to ship the weights ahead via UPS to wherever you are going to be working.
Peter Wiley is offline   Reply With Quote
Old November 7th, 2006, 04:55 PM   #3
Could you use water filled weights?
Old November 7th, 2006, 06:29 PM   #4
DVCreators.Net
Maybe just carry the smaller weights for fine tuning and use something else that can hold water to add weight. I've been dinged hundreds of dollars for overweight bags. Comes with the territory. Usually 50lbs in the limit on most airlines these days.
Here is a link to one of the weightbags from photoflex that you can fill up with water http://photoflex.com/Photoflex_Produ...bag/index.html
Also, Microdolly has a pretty cool weight cage where you basically just put your extra gear and/or water bottles in the cage. Not sure if this will work with your jib but it's nice to know about http://microdolly.com/micro_3.html
Guy Cochran
Old November 7th, 2006, 11:15 PM   #5
Thanks for your replies. I dont think the Weight cage will be compatible with my JIB arm. Also the water/sand bag will nto be a reliable option as the hole where it gets tied tot he jib arm i feel might come off any moment & will give way to imbalance my Jib at any point of operation. I have got no option to carry weights & end up paying $$$ for the same.
Cheers !
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
