Using the Everio with a Video Mixer at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
JVC's Everio Series 3CCD High Definition MPEG2 camcorders.
Old August 24th, 2008, 09:03 AM   #1
I want to do live online broadcasting and was wondering if could use the Everio's Out (S-Video, Component, FireWire, Composite) and connect to a Video Mixer such as:
Edirol / Roland | V-4 Four Channel Video Mixer | V-4 | B&H Photo
With the particular mixer above, I would have to use Composite, which is fine for now. I cant really afford an HD mixer yet. Just some insight would be nice, Ive never messed with video mixers before and Im just wondering if Im able to use the Everio with a mixer like above. Thanks!
GC
Gary Colon is offline   Reply With Quote
Old August 24th, 2008, 09:32 AM   #2
I don't see any reason why not. That should work. We do the same thing with GL2s at my high school.
That mixer though is pretty expensive. I assume that you're using multiple cameras, right? Otherwise there wouldn't be too much of a need for a mixer.
I've never tried it using multiple camcorders, but if you're on a mac, give Wirecast a go (link: Vara Software : Wirecast). You might be able to set up some sort of firewire hub and connect multiple cameras to that, then wirecast would allow you to switch between them on your computer. It's one possible solution that would be a little bit cheaper.
Glenn Fisher is offline   Reply With Quote
Old August 24th, 2008, 11:12 AM   #3
I had seen this program before but theyre not very clear on its capabilities. I plan on using 3 cameras and I want to transition between them not just "switch." I have been trying to find a Video Mixer that is at least half hardware and half software. Im going to try WireCast and see what it can do though. Thanks!
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC Everio GZ-HD and GZ-HM Series
