LANC or any type of zoom controler at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old September 17th, 2003, 11:43 AM   #1
Does the camera have an LANC or any type of zoom controller? I did a search that said, no. I find this hard to believe.
George A. Ross is offline
Old September 17th, 2003, 11:57 AM   #2
I did not find any lanc on the HD10, but then I was not searching for one, maybe a thorough search would be needed.
Eric Bilodeau
video SFX,DOP
___________________
http://www.fictis.net
info@fictis.net
Eric Bilodeau is offline
Old September 17th, 2003, 11:59 AM   #3
Isn't it that only Canon and Sony support Lanc? There isn't one on the JVC.
Paul
Paul Mogg is offline
Old September 17th, 2003, 01:14 PM   #4
I thought some sort of remote was standard on pro level camcorders. Perhaps I'm wrong. I've owned Sony & Panasonic & they both had remotes, Sony used LANC & Panasonic has a newer type.
Old September 17th, 2003, 03:44 PM   #5
HDV Cinema
Re: LANC or any type of zoom controler
<<<-- Originally posted by Utahbound : Does the camera have an LANC or any type of zoom controller? I did a search that said, no. I find this hard to believe. -->>>
Why?
LANC is a Sony design also used by Canon.
Steve Mullen is offline
Old September 17th, 2003, 05:13 PM   #6
Jlip on JVC isn't it called. I believe JVC are all alone with their standard. Does the camera have one of these?
I did a lot of searching for this befor and it was hard to get much info. JVC does sell a Jlip cable and I do recall software being available, but you would have to know some programing and some specific info on the camera that JVC might not give out, to make it of any use.
ken
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline
Old September 17th, 2003, 05:49 PM   #7
It does not have any control on it.
I guess, if you need control, it will be through a firewire cable, and that would be deck control. No zoom controller is available for it.
Cheers
DBK
Darren Kelly is offline
Old September 17th, 2003, 05:59 PM   #8
That sucks. Does it not have a seperate remote controll pad? Even my old 1 chip JVC DV had a remote.
ken
Old September 17th, 2003, 06:05 PM   #9
It comes with a remote which you could use I guess.
A little difficult to hold the remote and do a pan and tilt at the same time though.
DBK
Old September 17th, 2003, 06:58 PM   #10
True enough. You could mount the remote on the pan and tilt console and run it all from there. What kind of range/reception does the remote get you?
ken
Old September 28th, 2003, 11:31 AM   #11
I don't think either Hd1 or HD10 has any wired remotes. I also do agree that this sucks big time. Varizoom's LANC for Sony VX2000 has been a huge help. Being able to control both focus and zoom without touching the camera body is very important.
Also, what do you do when the camera is mounted on a crane? Bummer.
It does have a little wireless remote, but it's a joke - do not waste your time thinking you can use it reliably. Plus it only controls zoom but not focus, to my knowledge. Plus cam's IR sensor is located at the FRONT alongside the lens...
I'd seriously hope that next generation of these cams will feature a LANC-type wired, variable speed focus/zoom plus rec-stop/wake up remote. It is a handicap for JVC HD not to have such basic necessity.
Alex Raskin is offline
Old September 28th, 2003, 12:26 PM   #12
JVC used to offer Jlip packs for their older cameras. I hope a solution is put forth. What about the big JVC DV cams -500/700.
Do they have any remote controll options? They must have something available considering their market. Maybe the same setup will work on the JVC. Even if I have to use a pc to controll it through software (like varizoom but you use a keyboard) I would be happy.
ken
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
