JVC GY-HD 101 on crane at DVinfo.net
Old September 5th, 2007, 11:49 AM   #1
Has anyone mounted gy-hd 101 on jimmy jib b4? Im planning to replace my z1 with gy-hd 101. I love the fact that z1 has quick respond in focusing (auto focus) when its flying on the air, my question is how good jvc focusing? Also im using matrox rtx2 to capture my HD source material and premier pro cs3 as my NLE. Has anyone had any bad experience capturing JVC gy-hd 101 via firewire using matrox rtx2?
Thks
Dimar Brataadiredja is offline   Reply With Quote
Old September 5th, 2007, 01:15 PM   #2
Hello neighbor,
Just wrapped a shoot with the hd100. mounted it on a 12footer DIY crane.
This camera needs 20 pounds of counterweight on my set up.
This camera doesnt have auto focus. It has excellent focus assist. You can capture it even with OHCI firefire card and have no problems. I use edius.
Ted
Old September 5th, 2007, 01:35 PM   #3
Originally Posted by Ted Ramasola View Post
Hello neighbor,
Ted
How did you control the focus then since its manual? i do wedding videos most of the time and i think its gonna be hard if i have to control the focus all the time while the events is running live. Is it worth it to replace my Z1? can JVC be reliable to most of my projects? One thing that captures my interest in gy-hd 100 is that it can do 24p. Thks for ur help.
Old September 5th, 2007, 02:09 PM   #4
JVC101 Crane footage
Hi Dimar - Here are a couple of links for you.... Crane shots here and there in various locations with a range of moving subject matter.
http://www.studioscotland.com/knckhill.htm
http://www.studioscotland.com/hilton.htm
Camera - JVC HD101E
Crane by Kessler
Fitted - at times with matte box - at times without flags because of wind
IDX Battery Attached
Fujinon Zoom controllor attached
Connected to HD monitor
Always a good idea to work out your crane shots and focus to suit.... the JVC camera is a nice bit of kit but it does require a bit of planning before shooting. Is it what your looking for? I suppose a lot will depend on how you are used to working.
Regards: Stu
Stewart Menelaws is offline   Reply With Quote
Old September 5th, 2007, 02:39 PM   #5
Dimar,
While I do mostly corporate work and TV commercials with my HD100, I do have a consumer department that does event videography such as weddings. They are equipped with DVX100s. While this camera is amazing with its 24P and has pro features, I wouldnt trickle it down to my event videographers. One reason is its lack of auto focus and optical stabilization which is helpful in run and gun work. I plan to get them sony V1s which has 1080p.
Ted
Old September 6th, 2007, 05:18 AM   #6
Can the gy-hd 101 camera remote control the camera focusing? sorry for this new-bee question.
Thks
Old September 6th, 2007, 06:00 AM   #7
Theres no remote control on the JVC. You can find products that connect to the fujinon lens to control focus etc but these are not supplied with the camera
Paul Jefferies is offline   Reply With Quote
Old September 7th, 2007, 08:02 AM   #8
You can control zoom, focus, and pause / record remotely from a crane using a pair of Fujinon lens controllers... one for zoom and pause / rec, the other for focus. With broadcast video lenses, zoom and focus are almost always two separate controllers. Typically zoom and pause / rec is operated by the right hand and focus by the left hand.
There are a variety of different makes and models for Fujinon lens controllers. JVC and Fuji each offer their own zoom and focus controllers. Then there are third-party companies such as VariZoom Lens Controls whose products are usually a little more affordable.
Here's a zoom controller for Fuji lenses from VariZoom:
http://www.varizoom.com/products/controls/vzpgf.html
And here's a focus controller for Fuji lenses from VariZoom:
http://www.varizoom.com/products/controls/vzfcf.html
The 8-pin cable for the zoom and the teleflex drive cable for focus that's included in each controller kit is long enough only for tripod use, but you can easily add cable extensions for working with a crane. Hope this helps,
Old September 7th, 2007, 02:12 PM   #9
"The 8-pin cable for the zoom and the teleflex drive cable for focus that's included in each controller kit is long enough only for tripod use"
Might be worth noting that a Fujinon 4m extension cable for the 8 pin Fujinon zoom controller cost us £185.00 + vat (over $400.00) - OUCH!
Stu...
Old September 7th, 2007, 03:22 PM   #10
8-pin extensions from VariZoom run $110 to $140:
http://www.varizoom.com/products/acc...vzext8pin.html
Old September 7th, 2007, 03:24 PM   #11
The 8-pin extension cables from Varizoom are cheaper:
http://varizoom.com/products/accessories/vzext8pin.html
And they are a little cheaper than list price if bought from B&H.
Old September 7th, 2007, 03:26 PM   #12
Beat you by two minutes Jack! Ha!
Old September 7th, 2007, 04:31 PM   #13
Thanks guys.... but I'm sure our Fujinon cable uses a better quality of plastic...:-) - I'm off to be sick now.....
Stu
