Cleaning the heads at DVinfo.net
Old September 29th, 2007, 01:53 AM   #1
Cleaning the heads
The first time I cleaned the heads on my HD100, I waited until I started having problems with a tape. I had 177 drum hours when this took place and it took 4 10-second intervals to clean the heads to my satisfaction.
As a preventative measure, I feel that doing a single 10-second pass every 25-30 hrs would be a good preventative measure.
I'm using the cheap Sony Premium tapes so I don't know if that makes a difference.
How often do you guys clean the heads? Am I overdoing it?
Scott Jaco is offline   Reply With Quote
Old September 29th, 2007, 03:09 AM   #2
I don't think you're overdoing it. I run a head-cleaner everytime I start a new job or every 10-15 tapes. I use the JVC head cleaning cassette, but have used a Panasonic one in the past without issue.
Tim Dashwood
Tim Dashwood is offline   Reply
