Premiere Input Problem at DVinfo.net
Old June 8th, 2009, 06:52 PM   #1
Hey me and my friend shot some footage the other day in 720p and when we import it into adobe premiere pro cs3 the audio is off sync can anybody help me with this? Because i know with my canon i had to download settings for it to work right i wonder if its the same problem. Any pointers?
Thato Dadson is offline   Reply With Quote
Old June 9th, 2009, 09:40 AM   #2
I film exclusively using the JVC ProHD cameras and edit only using Adobe software. My pointer would be to try using Cineform as an intermediate codec. I'd recommend Cineform ProspectHD. You can download a trial version of it at http://www.cineform.com/prospecthd/
Once you have downloaded the trial then open a new Premiere project using the Cineform settings that correspond to your camera.
I have just finished a 110 minute feature film using this workflow and had no audio synch issues.
Hope that helps!
Dan
Canon C300 Mk2 x 2, Rotolight Anova Pro and Neos, Ronin Gimbal, Phantom 4 Pro UAV www.danthecameraman.co.uk
Dan Parkes is offline   Reply With Quote
Old June 10th, 2009, 04:02 AM   #3
Indeed with Premiere Pro, Cineform is the way to go.
Using the original m2t format to edit it slow and you loose a lot of detail.
The Cineform converts the files into a format very easily usable in Premiere, and you have 10-bit colorspace to adjust in post with ProspectHD.
Marc Colemont - Belgium - http://www.mc-productions.be
JVC GY-HM850's, HM890, HM600
Marc Colemont is offline   Reply
