CU-VH1 deck help at DVinfo.net
Old July 10th, 2009, 06:50 PM   #1
CU-VH1 deck help
I just got a used JVC CU-VH1 deck. It works as expected when capturing HDV tapes recorded on my HD100U, but when I try to capture standard DV it plays on the unit's screen, but no video is transferred through the firewire. In fact, if I try to capture using Vegas 8.0's SD capture utility, it tells me "The device 'Microsoft AV/C Tape Subunit Device' could not be opened."
Is it possible that this unit is not capable of spooling standard SD DV video? Tomorrow I will try to shoot some SD with my HD100 and see what happens.
BTW, if I try to capture using the built-in HD/SD capture utility in Vegas 8.0, it controls the deck (play, rewind, ff) but no video is transferred.
Chris Davis is offline   Reply With Quote
Old July 11th, 2009, 12:37 PM   #2
The specs for the CU-VH1 cite multi-format recording of both HDV and DV footage.
Reel Impressions Media - Make it more than a memory
GY-HD100- 7D- PSC Promix 3- Lectro/Sennheiser- Zoom H4- MPB- CS6/CC
Christopher Glavan is offline   Reply With Quote
Old July 13th, 2009, 07:56 AM   #3
I figured it out - there is a hidden DV/HDV switch, like the switch on the HD100. Unfortunately, unlike the HD100 there's not a big flashing "change the switch" reminder when it's in the wrong position.
Old July 14th, 2009, 10:30 AM   #4
I have this deck and one tip/instruction the manual says is to power down the deck before you switch between HD and SD (or Mpeg and DV).
Tup Wright is offline   Reply
