Component out resolution at DVinfo.net
Old September 18th, 2005, 12:54 PM   #1
I posted a similar topic on the HD10 forum but seems you guys took our thunder I will ask here because it is just as relevant for this cam.
An owner of a PAL dsr570 told me he was able to capture uncompressed 1024x576. I am curious if this is a similar to the uncompressed SD , which is available at 480p60 on both JVC cams? I know that it conforms to 720x480 to tape in HDV, but what about uncompressed? Would I get 1000'ishx480?
Probably not such a concern to HD100 users as they get 720p60 so no need step down to SD unless it was a matter of HDD speed or size. In regards does anyone know what kind of bandwidth is required for uncompressed SDp60 and or 720p60?
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline   Reply With Quote
Old September 18th, 2005, 02:05 PM   #2
Ken, I own a DSR-500 (NTSC) and I am curious to hear more, specs, reasons for doing this, etc.
www.ascentfilms.com
Jiri Bakala is offline   Reply With Quote
Old September 18th, 2005, 04:17 PM   #3
He said he made his own mod from the cam head pre compression. Not to tape/uncompressed are the reasons.
Seems the HD10/100 offer componet out uncompressed, I am wondering if it would be the same for SD.
Old September 19th, 2005, 10:17 PM   #4
Bump?
Bump!
Old September 19th, 2005, 10:30 PM   #5
You must be thinking about the Reel Stream Andromeda.
It is a mod done to SD cameras to hi-jack the RGB signal from the CCDs before compression and then send it to a laptop via a USB 2.0 port.
They also managed to get way higher resolution from the chips than the standard 720x480. The other benefit is that the 4:4:4 signal renders WAY MORE dynamic range.
Here's the link:
http://www.reel-stream.com/
Tim
Old September 20th, 2005, 01:48 PM   #6
No, ya I'm not really thinking anything anything to do with the Sony cam. But I would really like to know what resolution uncompressed SD component out is on the HD10/100.
