Split Screen Effect Still Present! - Page 4 at DVinfo.net
Old April 29th, 2006, 10:04 AM   #46
I've used +18 db gain on Betacam shooting a fly on the wall documentary with the police. It's best only used when content is important and you don't want to create a distraction using a light in volatile situation. It actually looks worse in the V/F than on tape because of the peaking.
However, that is rare and + 9db gain on a Betacam (when required) covers 99% of documentary work, including under street lights. For drama etc you want much lower gain settings (if any).
I suspect that the above sensitivity might be the same as using +12db gain on the JVC using Standard gamma.
It's a lot better to light than just to put in gain. All cameras have limitations and you have to select the right camera for the job you're doing.
Old April 29th, 2006, 11:36 AM   #47
Guy - Read this and see if 4:2:2 and 4:2:0 with DVCPROHD and JVC Flavor of HDVB is really that different.
http://www.bluesky-web.com/HDVHVX.htm
Tim Holtermann is offline   Reply
