Editing workflow & codecs on the Mac - Page 2 at DVinfo.net
Old May 9th, 2006, 01:25 PM   #16
HDV Cinema
Originally Posted by Shawn Kessler
hay steve would you mind explaining to me why I get so many dropped
frames when i edit native HDV in final cut pro. ive got 2.7 power mac
with 4.5 gigs of ram. it droppes frames every time. sorry dont believe you!
When you say dropped frames, do you mean during capture or during preview.
I capture on a G4 iBook (1GB) with no dropped frames.
I previewG4 iBook (1GB), even with CC and other filters, without dropped frames.
So you've got a problem with your system.
Old May 9th, 2006, 04:51 PM   #17
One of the simplest problems that causes dropped frames on playback is the viewer and canvas window size. Set these to "fit all". I think thats the correct one to use. Sometimes I inadvertently zoom in a window while working on a sequence. Same keys zoom the timeline and zoom the window. Suddenly playback get's choppy. Check that on your list of troubleshooting.
I get smooth HDV playback, realtime transitions, realtime titles and realtime color correction. Not sure how much is my Dual 2.3 and how much is the Aja Kona board. Today I tried to add a realtime TC Generator filter, but that pushed it over the limit and I had to render.
Changing the system prefs for playback also allows more realtime at the expense of lower quality and dropping frames. Good for previewing, though.
DB
Dave Beaty is offline   Reply With Quote
Old May 9th, 2006, 05:50 PM   #18
Since it works on your system, you don't think I will have a problem with the JVC on my Powerbook (G4, 1.33 GHZ, 2 Gig Ram)? I have FCp 5.1.
Steve Benner is offline   Reply With Quote
Old May 10th, 2006, 03:43 AM   #19
fcp dropped frames
Accually it dropped frames only in the sequence. But ive sience figured out the problem. seems there was settings in the sequence properties set
to 100% changed them to 50 and bam! no more dropped frames.
Shawn Kessler is offline   Reply With Quote
Old May 11th, 2006, 09:36 AM   #20
workflow and codecs
Our temporary workaround for the 24P issue (until FCP supports this frame rate) was to shoot in 720/24P, capture by having the BR-HD50 deck output 720/60P via the component out (deck control via Firewire), and have Blackmagic capture 720/60P using the DVCPRO codec. We can edit seamlessly and the results are beautiful.
michael
Michael Udris is offline   Reply With Quote
Old May 11th, 2006, 10:22 AM   #21
Originally Posted by Michael Udris
Our temporary workaround for the 24P issue (until FCP supports this frame rate)...
So FCP5 DOES NOT support JVC 24p?
DJ Lewis is offline   Reply With Quote
Old May 11th, 2006, 10:38 AM   #22
Currently it doesn't. Apple has demostrated a beta version at NAB that supported HDV 24fcp natively. No dates have been announced for the availability.
Paolo http://www.paolociccone.com
Demo Reel
Paolo Ciccone is offline   Reply With Quote
Old May 11th, 2006, 10:42 AM   #23
FCP cannot caputre the 720/24P from the JVC until the NAB update is released. FCP cannot edit native HDV without a quicktime wrapper, so the HDD drives also do not work until their firmware gets updated.
Currently, HDVxDV and Lumeire HD can capture the 24 Frames, but this is an involved process. I am getting this camera later in the day, and I don't NEED the 720/24P right now so I can wait a month or two.
For the record, the NAB update that allows for 720/24P capture should be a downloadable release in the next month or so.
