Finally, a sucessful slomo test. at DVinfo.net
Old May 10th, 2006, 10:54 AM   #1
I have finally created a decent looking slomo from SD60p
http://media.filmexposure.org/60p24p.mov
Adam Craig
Los Angeles, CA
www.showiki.com - Entertainment Biz Wiki
www.filmexposure.org - My Media Company
Adam Craig is offline   Reply With Quote
Old May 10th, 2006, 11:58 AM   #2
Great job, Adam. It looks very smooth and I can't detect the flicker I've seen on other samples. My camera's coming tomorrow... Hope to do lots of testing as well.
Chad Terpstra is offline   Reply With Quote
Old May 10th, 2006, 03:39 PM   #3
Slo-mo bike ride
Sob - the music and all - the saddest bike ride ever...
Lance Bachelder is offline   Reply With Quote
Old May 10th, 2006, 08:32 PM   #4
Excellent. Really smooth. Next year, the HD 200 will be able to accomplish this at 1280x720!!!
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old May 10th, 2006, 09:37 PM   #5
It's true... such a sad bike ride.
It just occured to me that next time you'll want to set your shutter a little higher to account for the slowdown. I think for 60p > 24p the best shutter is around 1/160th or 1/250. This way your cars will actually have the look that they were shot at 24p 1/48th shutter but moving very slowly. Can anyone confirm a good shutter to use with intent to slow down?
Old May 10th, 2006, 09:53 PM   #6
Nice looking slomo, I can definitely imagine using that for the "NFL Films look" for shooting sports.
Is there any particular reason you were having trouble focusing?
EDIT: In terms of shutter, 1/120 should work fine, it'll simulate a 180 degree shutter for "film look" purposes. For sports I'll go up to 1/250 in order to give good freeze frames and to isolate fast moving objects like hockey pucks a little better (makes them easier to follow too).
Stephan Ahonen is offline   Reply With Quote
Old May 11th, 2006, 10:19 AM   #7
I hadn't set the back focus and I'm new to this "real" lens. My old DVX100a was a lot different.
Adam Craig
Los Angeles, CA
Old May 11th, 2006, 12:08 PM   #8
Don't worry about it, you'll get used to it. The trick is just remembering where you're focused and pulling focus depending on whether your subject gets closer or further away. Get used to the focus assist feature, it'll help you "lock in" a lot easier.
Old May 20th, 2006, 08:25 AM   #9
Adam, you might be the first person to equate bike riding with "Platoon".
Andrew Peterson Padilla is offline   Reply With Quote
Old May 20th, 2006, 09:26 AM   #10
he he, objective: complete.
Adam Craig
Los Angeles, CA
Old May 20th, 2006, 10:14 AM   #11
Resolution loss
What sort of visible resolution loss is apparent when watching it on an HD monitor? That's assuming you have one, I still don't.
Otherwise, that was a great clip. The rider must be the most depressed bike messenger ever.
Old May 20th, 2006, 03:06 PM   #12
Transition?
Looks great, and promissing for something I have in mind.
What program did you use to convert the 60 > 24 fps?
Can you do a smooth transition from real-time to slow-mo?
Mathematically shutter of 1/120 should equate to 1/48, is this what you used?
And the music - William Orbit's "Pieces in a Modern Style", Handel, I think? Lost the album so I can't check.
James Daniels is offline   Reply With Quote
Old May 21st, 2006, 05:34 PM   #13
I'm glad you included sound. So many people post clips w/out sound and it just doesn't feel right.
Scott Jaco is offline   Reply
