Hdv 60p at DVinfo.net
Old November 9th, 2006, 03:20 PM   #1
Hdv 60p
Hey folks,
I am shooting a music video on Saturday. I am thinking of using the HDV-SD60p but I have one question:
I am doing some green screen work - will the HDVSD60p footage have 4:2:0 color space like 720p HDV or will it be 4:2:2 like the SD?
Also I am assuming you capture in MPEGstreamclip when using this format. When you export a quicktime for FCP what format do you use? AIC30p?
Cheers.
Ben Chace is offline   Reply With Quote
Old November 9th, 2006, 03:33 PM   #2
It is my understanding that the only way to get 4:2:2 colorspace is to digitize your footage as it is being shot via the composite out ports. I do not believe your frame rate alters this in any way.
I'm not sure how or if the firestore can digitize 4:2:2... Not sure about FCP.
john
evilgeniusentertainment.com
John Vincent is offline   Reply With Quote
Old November 9th, 2006, 04:21 PM   #3
Originally Posted by Ben Chace
Hey folks,
Cheers.
Standard Def DV is never 4:2:2. It is 4:1:1 in NTSC, and 4:2:0 in PAL.
Using the HDV SD60P setting will be 4:2:0 just like the 720P modes.
You should really do a green screen test to make sure SD 4:2:0 is going to give to satisfactory results. There are NLE plug-ins that "uprez" the other colour channels to help with keying. Graeme Natress designed one for FCP. You should search around for other options as well.
Tim Dashwood
Tim Dashwood is offline   Reply
