Zoom / Focus Display in HD100/200/250 at DVinfo.net
Old January 23rd, 2007, 12:06 AM   #1
Hi,
with std lens or TH13.x3.5 :
Does the Zoom / Focus Position of the lens show up (optionally?) in the display?
I found it to be a big help with some other cams to KNOW where Focus is without taking my eye of the VF.
ULi
Uli Mors is offline   Reply With Quote
Old January 23rd, 2007, 05:09 AM   #2
Originally Posted by Uli Mors
Hi,
ULi
Hi Uli,
No it doesn't. That's a feature of fixed-lens cameras like the DVX100.
Old January 23rd, 2007, 08:23 AM   #3
I used to work with DV5000 + Canon Lens (dont know exact model, 19x6.7?) and the display showed the values...
Anyway, thanks for your answer!
ULI
Old January 23rd, 2007, 10:48 PM   #4
I've worked with many interchangable lens cameras that show focus and zoom in the viewfinder, mostly of the high end live broadcast variety.
Stephan Ahonen is offline   Reply With Quote
Old January 23rd, 2007, 11:47 PM   #5
I just read the hd200 manual (pdf) and it seems that the hd200 does not offer that feature...
Unfortunately - I think, working in low light and "remembering" one or two focus distances is really helpful (instead of trying to focus each time).
Since I do weddings as well IŽll miss that feature...
(receiption: getting focus bride/groom, fastly changing to the priest, different focus, fastly changing back to bride reactions etc.)
ULi
Old January 24th, 2007, 03:00 AM   #6
ULI
Uli, I stand corrected (I was brought up in film). You could always try the focus assist, though I'm not convinced by this feature.
Old January 24th, 2007, 05:48 AM   #7
Why arenŽt you?
To be honest , this feature is one of the PROs I give for the HD100/200 etc.
THough "more serious" cams like the XDCAMS offer 1,5" CRT VF, it seems to be difficult enough to focus (pdw-f330 has 4:3 1,5" , letterboxed with 16:9, pdw-f350 has 16:9 2" CRT).
I just played with a hd100 once and was suprised about the VF , though its not a CRT and VERY SMALL (but magnified).
Anyway, a FOCUS READOUT could be very helpful, especially when focussing back to the same peoples position...
Old January 24th, 2007, 07:45 AM   #8
Images: 10
while the Focus Assist feature does provide some guidance, it is mostly at wide open aperture settings where light isn't a problem. In low light conditions or at apertures below f/4, there is such a broad range of focus settings that "indicate" you're in focus, that FA is relatively useless.
Old January 26th, 2007, 09:26 PM   #9
If you're at a small aperture where you're able to rack the focus a bit without FA telling you you're out of focus, that's not a bug with FA. It's because your depth of field is large enough that the subject can remain acceptably sharp despite racking your focus around. Best way to find the "optimum" focus point in that kind of situation is find the extreme focus positions where FA goes away, and rack your focus to the midpoint between them.
