Little tip at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 150 / 100 / 70 Series Camera Systems
GY-HM150, HM100, HM70 recording AVCHD MP4 & QuickTime .MOV to SDHC cards.
Old March 12th, 2011, 12:02 PM   #1
Little tip
I know many of you know this. If you shoot mov. and edit in FCP, in the settings change the render control from "same as codec" to Apple ProRes 422. It shortens the render time and gives much better quality in all effects. You will never see this dreadful message: "Conforming MPEG 2)
Finnur Bardarson is offline   Reply With Quote
Old March 15th, 2011, 09:54 PM   #2
Re: Little tip
Thank you. That is good info.
Andy Urtusuastegui is offline   Reply With Quote
Old March 31st, 2011, 10:13 AM   #3
Re: Little tip
Sorry - I don't think I get it.
Are you editing natively with the XDCam EX codec? If you're transcoding anything to Pro Res, you're losing the workflow advantage of shooting straight to the HM100's native MOV-wrapped format (XDCam EX) and running this native codec from acquisition to delivery.
Any transcoding effectively uncompresses the original codec to Base Band and then recompresses to Pro Res - so the quality would actually be worse than editing and rendering natively in XDCam EX.
Or have I waded in too enthusiastically and missed something?
Ben.
www.bengiles.co.uk
Ben Giles is offline   Reply With Quote
Old March 31st, 2011, 02:15 PM   #4
Re: Little tip
No, render goes faster. This advice comes from the "highest levels" . The output should be ProRes 422, bigger file but it use 4:22 and better qualiry
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 150 / 100 / 70 Series Camera Systems
