GoPro diving set up w lights - Page 2 at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
Covering the GoPro HERO and other small Point-Of-View video cameras.
Old May 31st, 2011, 11:08 AM   #16
Re: GoPro diving set up w lights
Thanks for the info Ron ... I am considering purchasing the ultra light TR-GP with TR-DHB handle Ultralight Control Systems - GoPro Accessories and the Aqua Sun eLed Rechargable: The AquaSun eLED Dive Light Underwater Kinetics
This Aqua sun seems like it would put out plenty of light and it says it is a wide beam but doesn't give specifics on how wide.
I will be shooting during the day but at depths up to 120 feet ... will I still need a pink filter with this set up?
Nick Clement
www.reelescapefilms.com
Nick Clement is offline   Reply With Quote
Old May 31st, 2011, 12:55 PM   #17
Thanks for the info.
Old May 31st, 2011, 06:32 PM   #18
The GoPro needs light. When things get a little dark, your footage will have a lot of video noise. Try shooting indoors and you will see what I mean.
120 feet is pretty deep. At that depth I would skip the filter and bring the biggest most powerful lights you have. Where are you diving ? Is the water clear ?
https://www.ronchauphoto.com/
Ron Chau is offline   Reply With Quote
Old June 2nd, 2011, 11:41 PM   #19
Headed to the Cayman Islands ... the water should be clear. I know what you mean about the gopro's noise problem in low light situations ... So the filter isn't necessary if I have enough light correct? I'm just worried about a drastic white balance shift in the middle of a sweet shot of tarpon or something : )
Nick Clement
Old June 3rd, 2011, 07:06 AM   #20
Filmed while snorkeling:
YouTube - #x202a;Bonaire - watercolors‬‏
Old June 3rd, 2011, 04:26 PM   #21
The filter helps with color at the expense of cutting out light. As you go deeper, the need for light can override the need for color. The exact depth where this takes place varies depending on water clarity, time of day and sunlight.
Typically filters for video are used for depths between 12 feet and 80 feet. I not aware of many recreational dives in the Caymans deeper than 80-90 ft. In my humble opinion, use the filter the whole time in Cayman Islands, unless you are doing a night dive or diving over 100 feet.
Bonaire, Hilma Hooker. Around 75-80 ft, low viz maybe 35-45 ft. Late afternoon. Using the filter. On this dive, the need for the filter out weighs the need for light.
Old September 24th, 2012, 02:54 PM   #22
Hello
i also search an affordable LED light for my underwater video with the gopro (medium FOV).
I will dive no more than 10m.
Any suggestion for the lamp? thx
Relaxing clips with waterfalls and music, 3D photos, 3D videos:
www.3d-video.hu
Prech Marton is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > Micro / POV Camera Systems
