Newblue FX at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > NewBlueFX plug-ins
NewBlueFX plug-ins
Stabilzer, blends, effects and more for Mac & PC editors.
Old October 8th, 2008, 04:59 PM   #1
Newblue FX
Where do I install the plug-ins? Which folder is it so they show up as a folder or within the list of other FX's.
John
John Griffin is offline   Reply With Quote
Old October 8th, 2008, 08:11 PM   #2
Speaking of NewBlueFX...They worked with me for a couple of weeks, yes, weeks, to clarify a challenge I was having with a plugin but man they worked hard and got it straightened out and I am a HUGH proponent of NewBlueFX. (something code or something went really goofy or some such thing) I have many of their plugins and can't say enough about them or the service from NewBlue.
Anyway, the plugin will automatically go to the correct folder or if it's not there it will defalut and install the correct folder. Once the program (plugin) is installed when you open Vegas, BAM! the plugin will be there in the VideoFX tab and then all you have to do is activate it from the dialouge screen OR you can activate it from the START>PROGRAMS>NEWBLUE>whatever the plugin is>MANAGE ACTIVATION. It's really a very simple process and should only take a few minutes at most.
Don
Old October 9th, 2008, 07:07 AM   #3
Sponsor: JET DV
Yes, as Don said you simply install them and they appear. The older installers required that you pick the installer for the appropriate application. The newer installers allow picking the proper product during installation so only a single installer is needed. Once installed, the effects will be seen on the Video FX tab and the transitions will appear on the Transitions tab.
Edward Troxel is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > NewBlueFX plug-ins
