When capturing should you hear audio from cameras onboard speaker? at DVinfo.net
Old May 26th, 2003, 04:36 PM   #1
I was capturing footage with my DVX100 tonight and noticed an echo. Reason being audio is heard in both the computer (because I have audio pass-thru set in Premiere) and thru the camera. Is this normal? I never noticed audio from the camera during capture before.
Glen Elliott is offline   Reply With Quote
Old May 26th, 2003, 06:28 PM   #2
I have a cheapo Sony Digital8 that I am using right now, and if I have my LCD screen out when I am capturing, I hear audio coming from the camera.
Jeff
Jeff Troiano is offline   Reply With Quote
Old May 26th, 2003, 08:03 PM   #3
My VX2000 does the same thing.
Paul Tauger is offline   Reply With Quote
Old May 26th, 2003, 08:12 PM   #4
This is normal.. when you're capturing you're basically just playing it on the camera like you would if you were watching what you shot normally, so there will be sound. This won't affect your capture file though. If this bothers you, you can always turn your camera volume down -- this won't affect the audio capture.
alextaylor.org
Alex Taylor is offline   Reply With Quote
Old May 26th, 2003, 08:21 PM   #5
It plays sound from the camera even with the lcd closed- is that normal?
Old May 26th, 2003, 09:24 PM   #6
Sponsor: JET DV
I just turn the volume down. Many capture programs can be told to capture but not play the audio during capture.
Old May 27th, 2003, 05:11 AM   #7
Curious- what capture program(s) do you use?
Old May 27th, 2003, 01:46 PM   #8
Sponsor: JET DV
Scenalyzer has an option to mute the sound on capture so it won't play through your speakers. I use both Scenalyzer and Vegas Capture.
Old May 28th, 2003, 07:34 AM   #9
same here. I have a canon xm2. I can turn down the volume on the canon. In vegas you have an option whether you want to here the capture sound (through the PC sound card) or not.
Either way this has no effect on the capture.
Cosmin Rotaru is offline   Reply With Quote
Old May 28th, 2003, 09:29 AM   #10
<<<-- Originally posted by Glen Elliott : It plays sound from the camera even with the lcd closed- is that normal? -->>>
Yes, it's normal. To mute the volume on your camera just turn down the volume (it's usually a dial or up/down buttons.)
alextaylor.org
