Pre render footage looks better?? at DVinfo.net
Old April 26th, 2008, 02:17 PM   #1
Hey guys...sorry if this was covered somewhere else...
I'm using Premiere pro CS3
Ok, this is the deal. I shot some video with a Canon XH A1.
Footage of objects with horizontal lines, i.e. brick walls, door frames...etc all seem to flicker after they are rendered.
I've tried EVERY combination of field options under the clip tab, and have employed the flicker removal option under the motion menu. I've tried blurs and every other effect I could think of to fix this. I've tried adjusting project settings and have read a lot of confusing tech babble.
Nothing works...I'm left with a serious flicker which stays with the product all the way to DVD.
Perhaps my footage is bad, perhaps my project settings are askew.
But here's the nub; the footage looks fine pre render.
Here, let me repeat that. THERE IS NO FLICKER APPARENT WHEN THE FOOTAGE IS "RED".
The footage CAN look clean...I can see it there not flickering...it gives me hope...
However, I have NO way to export this clean looking footage. All I can export is flicker city.
Please help.
Chris Huber is offline   Reply With Quote
Old April 26th, 2008, 03:54 PM   #2
solved
Ahhhhhhh...
This was a time re-mapping issue.
I disabled the frame blending option and this seems to have corrected the problem.
