Quick Time problem at DVinfo.net
Old August 27th, 2008, 04:29 PM   #1
Quick Time problem
I have produced a short video in the 16:9 format and am trying to output it to a Quick Time movie file. Each time I render the file it dispays it in the 4:3 format. I have rendered the file at least 8 times this evening using various settings.
Premiere Pro CS3, Output 500 x280, H264 codec, 44,000 16Bit Stereo, Pixel Aspect set to Pal Widescreen 16:9 also tried the 720 x 576 aspect in the hope it would stretch out, but so far no luck.
Any ideas anyone
Old August 27th, 2008, 06:44 PM   #2
Images: 10
you haven't mentioned what quicktime codec you've tried to render to. I've experienced that DVCPRO is anamorphic, and therefore very difficult to change the format size to anything but 4:3. There is a way,but, it's rather detailed. If you're trying to use DVCPRO, can you render to another codec?
Old August 27th, 2008, 11:37 PM   #3
I thought H264 was a codec. I have had to resort to outputting the movie as a FLV this has kept the 16:9 ratio.
Old August 28th, 2008, 07:03 AM   #4
Images: 10
my mistake, you did specify.
Old August 29th, 2008, 04:02 AM   #5
Just as a final note. I altered the settings within QuickTime Pro 7 player (Window > Show Movie Properties - Video Track - Visual Settings) I used the 853x480 setting and saved them (when you close the movie you are prompeted to save the settings). The file now plays in the 16:9 format.
I am sure that I should be able to render the file in the correct format from within the Adobe Media encoder, but for this project I have found a sollution.
Thank you for your help.
Vincent Oliver is offline   Reply
