Video Rendering Taking a Long Time at DVinfo.net
Old February 12th, 2013, 08:32 PM   #1
Hi,
I'm not sure if I've done this right, as it is my first post in DVInfo :)
Basically, when rendering full HD video, the render times are very long (45 mins for a 1 min clip)and I was wondering if I was doing something wrong!
This is my set-up >>>
Windows 7 Professional 64-bit
Adobe Photoshop CS5 Extended
Pentium Dual Core E6600 3.06GHz
8GB Ram
nVidia GeForce GT 640 GPU
And these are the settings I am using to render video in Photoshop >>>
Exporting as 1080 HD Quicktime
H.264 compression - compressor quality = High
Frame rate as original
Key Frames = Auto
Data Rate = unlimited (but doesn't seem to make much difference, even if it is limited to, say, 2,000kbits/sec
I am wondering if I am doing something wrong!
Dave
David Humphreys is offline   Reply With Quote
Old February 12th, 2013, 08:56 PM   #2
Re: Video Rendering Taking a Long Time
Uhm... are you rendering only in Photoshop, or are you mentioning that as somehow a reference to having problems rendering in Sony Vegas?
Rendering video in Photoshop is not ideal, if you have an Adobe suite of programs, try Premiere or After Effects.
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old February 13th, 2013, 07:04 AM   #3
Thanks Gerald ... I thought I was posting in a "general" post production thread ... oops!
I was rendering through photoshop, so has nothing at all to do with Sony Vegas.
I'll give Premiere a go and see what happens - thanks :)
Old February 13th, 2013, 09:17 AM   #4
You won't have much better luck in Premiere Pro CS5+ with that system: The CPU just barely surpasses Adobe's official minimum CPU requirements just to run Premiere at all. With such a weakling CPU and GPU, your system might end up being as much as 20 to 30 times slower than a fast i7 system.
Randall Leong is offline   Reply With Quote
Old February 13th, 2013, 11:34 PM   #5
Yep. What Randall says. Time for some new hardware if you want to enjoy your NLE experience methinks. Go check out the Premiere Pro Hardware forum to see what is realistic for H.264 with Adobe editors.
Adobe Community: Forum: Hardware Forum
Stills at: www.flickr.com/photos/trevor-dennis/
Trevor Dennis is offline   Reply With Quote
Old February 14th, 2013, 09:16 AM   #6
In addition to what I stated, David, have you ever checked your system's disk setup? You see, cramming everything onto the system's single OS/programs disk will slow down your exports substantially - as much as six times slower than if the OS/programs disk and the media/project disk are completely separate.
Old February 14th, 2013, 08:30 PM   #7
Thanks everyone! You have been most helpful :)
Old February 18th, 2013, 02:13 PM   #8
I just installed cs6 and the Premiere Pro renders were painfully slow on a fast i7 system with a dedicated video drive. Updated the video card driver and it's purring now.
Duane Adam is offline   Reply With Quote
Old February 26th, 2013, 11:09 AM   #9
I would also have to say that your CPU is pretty... well, outdated to current standards.
I had previously AMD Phenom 4-core CPU and I tried to render some 1080p30 h.264 video and render time was about 2 hours for a 5-15 minute video.
After upgrading to a better CPU, I have been very happy with rendering times.
Hardcore Game Recorder
Ilkka Pouhakka is offline   Reply
