Desktop to firewire (dv) at DVinfo.net
Open DV Discussion
Old June 19th, 2003, 05:49 AM   #1
I am looking for a software that can output my windows desktop to firewire. What I'm trying to do is to make an instructional video on a software and would like to record the entire screen with mouse movements and all to an external device.
I know there are a couple of screen-capture sw's out there that can save my desktop to file, ex. avi. However that is not really working for me due to a too slow machine.
Anyone got any advice?
Best regards,
Sam Eklund
Stockholm, Sweden
Sam Eklund is offline   Reply With Quote
Old June 19th, 2003, 06:55 AM   #2
RED Code Chef
The best thing would be to get a video card with composite and/or
SVHS out and hook that up to a VCR/DV deck or DV cam. Easiest
way.
I don't think there is any soft that can send your desktop through
firewire in realtime while compressing DV. That'll take much more
CPU time then the software you mentioned.
My approach doesn't require any software what-so-ever. Only a
video card with analog out (some cheap GeForce cards have it,
most laptops do). You do need to lower your desktops resolution
for it to work, though.
Rob Lohman, visuar@iname.com
Old June 23rd, 2003, 12:59 AM   #3
Ok, thanks Rob, however that's not really what i'm looking for, I need for my screen resolution to be approx 1024 X 768 to fit all the windows I want in there. However, this is a very good low-cost approach to the problem.
Old June 23rd, 2003, 01:05 AM   #4
I think someone makes a box that will convert a regular monitor out into a TV out (S-Video or composite) and it handles high res. Dont remember off the top of my head. Maybe try doing a search or call some video computer specialty store. Only thing is, it might just be better (and cheaper) to just upgrade your computer. Good luck!
Scott Silverman
Shining Star Digital Video Productions
Bay Area, CA
Scott Silverman is offline   Reply With Quote
Old June 23rd, 2003, 09:14 PM   #5
Another solution is to record to desktop and your movements to a file using Camtasia, and then load that into your NLE, optionally edit it, do voice overs, etc., and then render to the format of your choice. If your NLE can zoom in on the video (Vegas can do this easily), you can highlight the area of interest as you go. I have also seen good results shooting video off of an LCD screen (not a CRT, it will flicker).
///d@
Dennis Adams is offline   Reply With Quote
Old June 25th, 2003, 08:03 PM   #6
Can't be done -- not in the way you're thinking anyway.
The standards are mismatched. Native DV -- even over Firewire -- is only 720 x 480 (or thereabouts). Your 1024 x 768 will still have to be downsampled to that actual resolution. Therefore a standard S-Video output WILL show the full screen, but only at 400 lines.
Dumb Guy.
Brendan Getchel is offline   Reply With Quote
Old June 26th, 2003, 01:14 AM   #7
Ok, I think I'll try and use the s-video out way of doing it. I guess, depending on what graphics card I use, the actual S-video signal will contan the whole 1024 x 768 screen, however, downsampled.
Fortunatley I'm working in PAL, thus having a few more lines to work with in the end product.
Thanks a lot for your time and your input!
/ Sam
Old June 26th, 2003, 06:05 AM   #8
I have done something similar to what you want. Using my GeForce 4 TI-4200 card that supports dual output you can run the main display in 1024 x 768 and simultaneously have S-Video or composite out to your camera. Use "Nview" from Nvidia to control that.
Of course the output to the camera will be downsampled as already mentioned. The resulting image on tape will be considerably blurry, and any small text you have in 1024 x 768 will be illegible on video.
Hans Henrik
Hans Henrik Bang is offline   Reply With Quote
Old June 28th, 2003, 12:49 PM   #9
(swedish)
du kanske har en av-out från din dator, kanske i s-vhs eller vanlig, som du kan koppla in i dv-kameran om du har av-in, funkar kanske=)
- jeha!
Jesper Hallen is offline   Reply With Quote
Old July 11th, 2003, 10:13 AM   #10
RED Code Chef
Keep it in English please! Thank you.
