Lightning help ! My movies seems yellowsh ... at DVinfo.net
Open DV Discussion
Old January 13th, 2008, 02:44 PM   #1
We just bought a new light equip:
http://www.atek.com.br/imagens/produ...igilight_m.jpg
4 x 55W (220W)
We are using 2 of these on 45º, 1 pointed from top to bottom and another on middle position.
Our movies are looking yellow, what we should do to avoid this? We did proper WB and original profile setup on the camera (SONY-FX1).
SAMPLE MOVIE
Do we need get more lights? I was thinking about two of these:
http://www.atek.com.br/imagens/produ...al_light_m.jpg
(4 x 45W - (180Watts)) at the bottom to avoid shadows and another (220W) on center.
Any other lightning recommendations?
Henrique Meneghelli is offline   Reply With Quote
Old January 13th, 2008, 05:09 PM   #2
White balance could correct the problem. Just add a 3 way color corrector filter to the clip and use the eye dropper to set the white balance. You can also use the color wheels to push the color away from yellow (toward blue) to get rid of the yellowish cast.
Ideally, you'd want to set your white balance in the camera on the set by zooming and focussing on a piece of white paper in the same light your subjects will be situated. <edit>Since you're already white balancing, you could white to a slightly yellow card (which will push the camera toward blue a bit) or just gel the lights blue after you WB</edit>
warning for the public: this is an innocuous (unthreatening and safe for workish - other than the watermark in the corner) clip from an adult film.
Web Youtube Facebook
Last edited by Cole McDonald; January 13th, 2008 at 05:16 PM. Reason: just re-read original post
Cole McDonald is offline   Reply With Quote
Old January 13th, 2008, 05:14 PM   #3
Those are some pretty nice prices on those lights too :)
Old January 14th, 2008, 03:36 PM   #4
Thanks for the tip, dont worked very well but I can see some improvment. I was thinking about some correctiong on the production, will try some gels maybe, on such lightining will be hard to do it but will try.
Im affraid about doing many corrections on editing software cause some of these adjustments dont work well on the playback.
Old January 14th, 2008, 09:05 PM   #5
you could also add a blue filter to the lens after white balancing...that would let you forgo adding all that gel to every light.
Old January 15th, 2008, 01:12 AM   #6
Thanks for the laugh!
Anyway, to answer your question: If doing everything Cole says did not help, your lights may not be truly white. Check their CRI. It should be over 90.
Emre Safak is offline   Reply
