Dirty heads- does that mean ruined tape? at DVinfo.net
Open DV Discussion
Old June 25th, 2003, 06:43 PM   #1
I recently have been having problems with my brand new DVX100 as of today. The camera is giving me the "dirty head" message even though I've never mixed tapes, etc. Towards the end before I stopped filming and shut the camera off the play back started exitibing artifacts, though when I'd hit stop then play again it would clear up.
Well now I got home and tried playing that tape back in my GL-1, the whole tape is fine until the end where it started exibiting artifacts playing back in the original camera. The footage exibited artifacts (though not as bad as when played back originially from the camera that shot it) but the audio was consitantly damaged. Almost shrill sounding, kinda hard to explain.
That leads me to my question- if, say for the sake of argument, your heads end up getting dirty during a shoot (somehow) does that "always" mean the glitches will transfer to the tape? Also if it does how come the glitches (digital artifacts) don't seem to have any continuity. Sometimes they show up when playing and sometimes they don't?!
Glen Elliott is offline   Reply With Quote
Old June 25th, 2003, 07:34 PM   #2
Unfortunately, yes.
The for glitches being random may be that the signal is almost there and when it is, the error correction can give you a clean signal. Other times there is just too poor a signal for recovery.
Why don't you clean the heads on the camera and then dupe the tape to your GL1. You may have to play the damaged area a few times but you might then be able to retrieve almost inact footage when you piece it together on a timeline.
Mike Rehmus
Old June 26th, 2003, 04:03 AM   #3
How would you dupe a tape between two cameras? Also if/when I run the headcleaner I don't know if I'll allow another sony tape to hit my DVX...ever.
Old June 26th, 2003, 09:14 AM   #4
Place the camera elected to record into record mode, the player camera into play. Firewire cable between them.
Mike Rehmus
Old June 26th, 2003, 10:24 AM   #5
Hmm I'd need some sort of special firewire cable then. Correct?
Old June 26th, 2003, 01:34 PM   #6
<<<-- Originally posted by Glen Elliott : Hmm I'd need some sort of special firewire cable then. Correct? -->>>
Just a 4-pin to 4-pin assuming that is what both cameras sport. To me, that's sort of a normal cable and readily available.
Mike Rehmus
Old June 26th, 2003, 01:53 PM   #7
Not to me- the only I've seen is the 4 to 6 (I think it is) the standard ieee1394 you'd use to connect to a firewire capture card.
Old June 26th, 2003, 02:03 PM   #8
Glen,in computer stores you will see the 4/6, in video stores you will find the 4/4 cables
Andre De Clercq is offline   Reply With Quote
Old June 26th, 2003, 02:17 PM   #9
Interesting. My editing cards, which do have firewire connections all have 4-pin connectors. I thought (shows what I know) that only the macintosh side needed the 6-pin to 4 pin cables.
Anyway, places like the Firewire Depot have any flavor you wish.
Mike Rehmus
Old June 27th, 2003, 08:24 AM   #10
You can find the 4 to 4 pin connector at Sears.
My Sony has both 4 and 6 pin ieee 1394 connectors, 4 pin in front 6 pin in back.
Ron Little is offline   Reply With Quote
Old June 27th, 2003, 08:50 AM   #11
Not to contradict Mike, but many PCI FireWire cards have 6-pin connectors. Most laptops and almost all camcorders have 4-pin connectors (with the sole exception I'm aware of being the Sony DSR-250). All three types of FireWire cables (4 to 4, 4 to 6, 6 to 6) should be readily available.
Old June 27th, 2003, 12:46 PM   #12
I found a place that sells 6 to 4 pin adapters for $10. Seem to work well.
Mike Rehmus
Old June 28th, 2003, 02:16 AM   #13
similar problem
Hi Glen
I recently had a similar problem occur. I shot some footage with my mx300, the footage was terrible! I sent the cam away for a service (needs full cyl head replacement) and during that time we hired an xl1-s for a shoot. I used the xl to veiw some of the damaged footage from the mx300 and all of the video was fine.....well actually spotless......
Just thought id chip in...
Rich
Richard Austin is offline   Reply
