multiple recorders software at DVinfo.net
Open DV Discussion
Old September 25th, 2009, 12:09 PM   #1
Hi
I am looking for a software to have an option for using two or more burners as recorders simultaneously to make multiple copies of the same source. I have Nero 8 essentials but I can't find this option anywhere.
Stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old September 25th, 2009, 01:37 PM   #2
Gear Pro:
Burn CDs to multiple drives simultaneously, Burn DVDs to multiple drives simultaneously
Yossi Margolin is offline   Reply With Quote
Old September 26th, 2009, 04:14 AM   #3
In full version of Nero there is on Burn tab selection "Use multiple recorder". I have used 3 recorders and it works well if each one is in separate IDE channels. If there is two burners in same channel it won't work. I haven't tested with SATA drives but it should work like IDE.
Mika Varis is offline   Reply With Quote
Old September 26th, 2009, 11:38 PM   #4
Thank you guys for the info. I finally bought Nero 9 from OEM Downloads for only $39 and has the multiple recorders facility.
Stelios
