Battery Power at DVinfo.net
Open DV Discussion
Old July 14th, 2005, 11:27 AM   #1
Battery Power
Hi there - Was wondering if there would be any reason I couldn't use this in a pinch. I have a Bescor battery that came with a Bescor light. It has an adapter so you can plug a regular household plug into it. I have used it for powering a monitor, lasted 14 hours straight, used it to power a betacam. If needed, couldn't I do the same with a DVX or XL1s? Thanks very much.
Michael Best is offline   Reply With Quote
Old July 17th, 2005, 05:18 AM   #2
RED Code Chef
If it has a normal power plug I would not see why not.
Rob Lohman, visuar@iname.com
Old July 17th, 2005, 07:28 AM   #3
Sean McHenry has written about this topic several times regarding the PDX-10. I think what he says is pretty generally applicable however:
http://www.dvinfo.net/conf/showpost....04&postcount=4
http://www.dvinfo.net/conf/showpost....81&postcount=7
http://www.dvinfo.net/conf/showpost....63&postcount=6
Also see the last few posts in this thread:
http://www.dvinfo.net/conf/showthrea...696#post331696
