Homemade "rail" system at DVinfo.net
Open DV Discussion
Old June 25th, 2010, 04:04 PM   #1
Just wanted to share a littel experiment I did that you can implement into your workflow, especially if you are on a tight budget like me. I have taken an ironing board and made it into a homemade "rail" system. If you get something smooth to slide across the top (in my case a large white balance card or piece of smooth metal) it will slide across the top surface with the camera a you will get beautiful smooth results. And the great thing is that it's extremely light and it's a built in tripod for the dolly shots. Now it can be wobbly without stabilizing the camera well and there are limitations to the angles you can get. Try it out and let me know what you think. I am going to test this out this weekend for some nature shots with my letus extreme and hopefully post some test shots. It's not a fancy dolly system, but for some nice slow "rail" type shots, you can't beat it, especially for the price.
Justin Brown is offline   Reply With Quote
Old June 26th, 2010, 04:57 AM   #2
Justin, starch or no starch? :) Nice idea. I wonder if a tripod head could be attached to an old iron.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old June 26th, 2010, 10:41 AM   #3
I would think a nice, stiff board...something like birch maybe...with a serious bit of urethane, could be a an excellent surface with nothing more than a soft cloth as the "slider" under the camera. (maybe some slightly raised sides so the camera can't leave the board surface as the videographer is concentrating on the shot instead of keeping the camera on the board...)
...maybe with a tripod/monopod support system, or two tripods...even a couple of rigged, heavier light stands would probably be adequate for a small camcorder or not too uber-rigged DSLR maybe?
Once I used a skateboard on a kitchen counter...lots of interesting possibilities out there.
TimK
Kolb Productions
Tim Kolb is offline   Reply
