Need Help - HM700u - CS4 - Popping Audio at DVinfo.net
Open DV Discussion
Old August 25th, 2010, 03:23 PM   #1
I don't understand...
The audio sounds great straight off the camera in my headphones - nice and clean.
When I work with the clips in Premier & After Effects CS4 it is loaded with popping.
I recorded in 1080i MP4 (not .mov)
My comps and seq in both premier are set up correctly I think....
Premier Template:
1080i 60 in XDCAM HD ( audio at 48kz )
After Effects:audio is set to 48kz as well.
I tried to use every different sample rate in premier just to see what would happen and it all popped real bad still.
Again - it sounds great off the camera.
The clips will not play back in QT player and in windows 7 player the vid plays but audio wont play back....
I'm in a real bind
Carlito Sanchaz is offline   Reply With Quote
Old August 26th, 2010, 07:59 PM   #2
lol this isn't looking to good :P
Old August 28th, 2010, 10:53 PM   #3
well i found the solution....
Update the software.
My production machine never goes on line and I thought I might see if updates would help - they did... Problem solved.
Hope this might help some one else in the future.
