After Effects equivalent of Photoshop LEVELS?! at DVinfo.net
Open DV Discussion
Old April 13th, 2014, 09:20 AM   #1
When using Photoshop's LEVELS, it is super simple to set your white, black and gray points with three clicks, and then make adjustments with those values locked in. What is the equivalent of this in After Effects?
I have tried the method of bringing a screen-grab into Photoshop, setting white, black, gray, and then dragging individual R, G and B values on the curve till the numbers are "balanced", but have always had lackluster results.
I know, this method is too crude an adjustment for a lot of applications, but sometimes it's a good starting point.
Casey Danielson is offline   Reply
