How to Do This Transition at DVinfo.net
Open DV Discussion
Old October 18th, 2017, 08:13 AM   #1
I am interested in doing the transition you see in this video around :35. It that much easier than I'm making it out to be?
Additionally, the transition right after that (from sitting at a table looking at laptop to singers) is something I'd love to learn as well. Any suggestions on how to do that? It looks like someone walking and as they walk, they transition from one shot to the next.
Brock Burwell is offline   Reply With Quote
Old October 18th, 2017, 08:34 AM   #2
Re: How to Do This Transition
Hi Brock
Have a look at this tutorial (for FCPX) I think it might give you some clues. Also check out the other stuff Ryan Nangle has on his tutorials.
It may work even better on a 1080 window in 4K footage.
Cheers
Tim
Tim Lewis is offline   Reply With Quote
Old October 18th, 2017, 08:40 AM   #3
First one is essentially a slide or push between two shots with a blur effect applied. Second one is ether a keyframed mask or a simple wipe timed just right. The reason it works is because of the continuous camera and subject movement in the correct direction.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old October 18th, 2017, 10:11 AM   #4
Something I noticed was an excellent use of color when transitioning shots. Someone was paying a lot of attention to color in flow and context.
Steve
www.CorporateShow.com
Old October 23rd, 2017, 04:36 AM   #5
Hi Brock
I have been spending the week trawling the net for FCPX stuff and found a plugin that seem to do exactly that transition. It is called Andy's Swish Transitions and comes from Andy Mees and is available for FCPX, Motion, Ae and PP through the FxFactory app.
Cheers
Tim
