GS400 or VX1000 at DVinfo.net
Open DV Discussion
Old November 5th, 2005, 09:47 AM   #1
GS400 or VX1000
I am in need of a new cam right now and I cant decide what cam that I want to get. I just wanted to know what cam would produce a clearer image between the vx1000 and gs400 and which cam has more effective pixels. Thanks
Andrew Mills is offline   Reply With Quote
Old November 5th, 2005, 10:17 AM   #2
I don't know which one has the most pixels, but pixels aren't that important either in a video camera.
For what do you want to use it?
The VX1000 is a very old camera, especially when you compare it with a GS400.
But its chips are a little bit bigger.
If you want to do narrative work, films, you maybe better look at the pannys, because they will give you a faster filmlook then the sonys.
What's your budget?
Mathieu Ghekiere is offline   Reply With Quote
Old November 5th, 2005, 10:44 AM   #3
The GS400 has higher resolution, although smaller, CCD's. It is capable of producing real 16:9 which is something that the VX-1000, VX-2000 and VX-2100 can't do.
Of course there might be other reasons to choose the VX-1000, but it's getting really old and might have a limited lifespan.
Old November 5th, 2005, 11:42 AM   #4
The reason why resolution and pixels are so important to me is because I need a cam that will produce a crystal clear image without artifacts. I got rid of my gl1 because the image was below mediocre and it produced too many artifacts.
Old November 5th, 2005, 02:38 PM   #5
Depending on your expectations, you may be searching in vain. I did some test shots awhile ago to explore the level of detail in a wide shot with two different DV cameras. I used the PDX-10 which has three 1/4.7" CCD's with the same resolution as the GS-400. I compared these to the same scene shot by a VX-2000 which has larger but lower resolution chips. As a point of reference, I also took shots with a 5MP Nikon digital camera and downsampled them to 720x480 resolultion then compressed them with the DV codec.
Draw your own conclusions....
http://greenmist.com/dv/garden/
http://greenmist.com/dv/res/
Old November 5th, 2005, 04:07 PM   #6
The links are not working.
Old November 5th, 2005, 04:14 PM   #7
Hmm, they work for me and I've tried through two different ISP's....
Maybe just a temporary glitch?
Old November 5th, 2005, 05:23 PM   #8
GS400 hands down. Great manual controls. Superb picture manipulation and adjustment. Amazing color reproduction. Real 16x9. Very compact. Best frame mode available, IMHO. The VX1000 is a good camera, but it's kind of a dinosaur.
Tony Tibbetts is offline   Reply
