Camera Colors bars, what do they do? at DVinfo.net
Open DV Discussion
Old March 9th, 2006, 10:35 PM   #1
Just wondering if the bars in a camera are for the editor to align his signal to?
Brendan Sundry is offline   Reply With Quote
Old March 10th, 2006, 12:41 AM   #2
And for setting up machines when you dub them.
Although I find them rather useless in editing. The Black and White levels are always off, and the color as well. I always scan thru a tape and look for the darks and lights to set my levels too, and adjust the color to what pleases my eye.
But I think they are supposed to be for us in theory, just not in practice.
Shane Ross is offline   Reply With Quote
Old March 10th, 2006, 10:55 AM   #3
In camera use of color bars
Are there Pantone cards that we should use to compare to our color bars or are we supposed to have a photographic mind and very trained eyes to determine just how "out" the colors are.
I guess simply is where is the standard to compare the color bars to? I was a telecommunications student in high school 20 years ago with our own small TV Studio full of donated equipment. We used to use the color bars then to adjust all our monitors, I just can't recall the specifics after all these years (I followed a different path and just now getting back into it).
Greg
Greg Drusjack is offline   Reply With Quote
Old March 10th, 2006, 11:08 AM   #4
bars
I use the bars to set up my field monitors and to make sure my viewfinder (diopter) is in focus.
Peter Costello is offline   Reply With Quote
Old March 10th, 2006, 11:34 AM   #5
Exactly - with the monitors setup using the bars, one can then visually adjust the lighting and the camera colour temperature and levels and see what those adjustments are actually doing to the signal. Otherwise you'd be in the position of not being able to say that green tint you see on the image displayed in the monitor on set was due to the monitor setup being off or to the colour temperature setting in the camera being off
Old March 10th, 2006, 03:52 PM   #6
1- They are used to align the levels in a signal chain... like how 1khz tone is used for audio.
To calibrate monitors:
http://www.videouniversity.com/tvbars2.htm
Another use of color bars is in conjuction with a waveform monitor and vectorscope. You can align decks/VTRs this way.
Tektronix has some great information about this on their website.
2- There are no Pantone cards to match the color bars to as far as I know. However, some companies make something like that... they are physical test charts like Chromadumonde.
http://www.dsclabs.com/chromadumonde.htm
You can 'paint' a camera (tweak its settings) until the colors on the chart line up in a vectorscope. Typically, only the higher end cameras have the settings that allow this.
Glenn Chan is offline   Reply
