Getting formats correct at DVinfo.net
Open DV Discussion
Old July 26th, 2006, 09:06 PM   #1
I am new to this forum so please forgive me if this has been hashed over 1000 times. I couldn't find it.
I am using an Canon XL2 in 16:9 format. I am capturing it in FCP 5 in the anamorphic setting. looks fine in FCP but when I export it to Quicktime, it looks like squeezed up 720x480.
At the end of the day, I want to both make it web ready in 16:9 and, more importantly, I want to produce a DVD and have the aspect ration work out.
Thoughts? Should I be doing something different? I hope so because what I have isn't working.
Thanks for any help.
paul
Paul McGowan is offline   Reply With Quote
Old July 26th, 2006, 10:35 PM   #2
Paul, are you just using default settings when exporting to Quicktime? You might want to make sure that you are using a setting that is 16:9, and not 4:3 which is often the default setting. When it comes to making something "web ready" I find I usually have to customize the settings for the clip to make sure the aspect ratio holds true.
Cal Johnson is offline   Reply
