Anton Bauer battery charging question at DVinfo.net
Open DV Discussion
Old March 13th, 2007, 02:49 PM   #1
I have a quick question about the Anton Bauer gold mount. If I have the gold mount and a battery attached to it, is there any way to charge the battery while it's on the camera without one of those titan on-camera chargers? In other words, can the gold mount itself charge a battery?
The camera is an HD100.
Jad Meouchy is offline   Reply With Quote
Old March 13th, 2007, 04:52 PM   #2
Hi Jad,
Unfortunately, no. Anton Bauer batteries are quite sophisticated and the AB chargers are really the only devices that can communicate with them appropriately.
If you want uninterrupted power, and can't use AC, Anton Bauer does make a hot-swappable gold mount, in which you mount one battery on each side. When one dies you may remove it, and the second battery will keep the power going. The dead one can be placed on a charger and be replaced by a live one.
Hope this helps.
Best,
Afton
Afton M Grant, Steadicam Operator
www.aftongrant.com | www.steadishots.org
Afton Grant is offline   Reply With Quote
Old March 20th, 2007, 01:03 PM   #3
Anton/Bauer
The Titan-70/Tandem-70 (name change at last NAB) is a charger or A/C power supply, it does not do both at the same time.
So you can operate the camera of of an A/C mains or charge the battery.
We went for the smallest size and weight when making this unit.
Scott Keyworth
Anton/Bauer, Inc
Scott Keyworth is offline   Reply
