HELP urgently needed - beeping noise at DVinfo.net
Open DV Discussion
Old June 24th, 2007, 02:46 AM   #1
Hi, can anybody help solve this problem. I am trying to edit footage in Movieplus 5. When I am in video capture and play back the footage in the timeline I get a high pitched beeping noise. All sounds under audio properties are turned off on the PC. ANY help would be much appreciated. Thanks
Jean Yeates is offline   Reply With Quote
Old June 24th, 2007, 04:48 AM   #2
Hi Jean, I've never used movieplus 5 but in Final Cut Pro when the audio needs rendered it beeps during playback. If rendering is the problem your timeline settings are conflicting with the audio sample rate on your footage for example your timeline may be set to 44,000khz and your footage is 48,000khz, go into the timeline settings and set the audio sample rate to the same as your footage and you won't need to render.
Hope this solves your problem, if not you need someone who knows movieplus 5.
Andy.
Actor: "where would that light be coming from?"
DP: "same place as the music" -Andrew Lesnie-
Andy Graham is offline   Reply
