One more feature missing - Page 2 at DVinfo.net
Old May 28th, 2003, 05:44 AM   #16
I'll try and run a more accurate test today because I just checked the DV953 manual (p.26) and it mentions 35mm (1.4") for macro from the lens.
Tommy Haupfear is offline   Reply With Quote
Old May 28th, 2003, 09:03 AM   #17
<<<-- Originally posted by Tommy Haupfear : Looks like the DV953 has the Fluroescent feature judging by p. 31 in the manual.
Here is a link to download the DV953 manual
http://im1.onecall.com/Image_Product...V953manual.pdf
or here is a capture of p. 31 (only the relevant part).
http://image1ex.villagephotos.com/2771042.jpg -->>>
Holy crap...
i jsut checked my cam (Pal MX500) and it doesnt have this fluro light setting :(
But in all honesty even without it if u set it to outdoors, it will make up for the blue wash you get when using incandescent light settings...
I dunno what relevance the flurou light would honestly have... :(
ive never seen the benfits so i cant make a jsudgement on whether or not we're missing out on much..
Peter Jefferson is offline   Reply With Quote
Old May 28th, 2003, 09:14 PM   #18
Hope, neither is it on my MX350-EN. No flourescent WB. That's why I end up doing manual WB all the time...
Yow Cheong Hoe is offline   Reply With Quote
Old May 30th, 2003, 09:51 AM   #19
Supplied Battery:
MX5K: 2700mAh
953: 1500mAh??? (according to the Chuckmeister)
MX500: ??
True or not, it's not a big deal. It's highly recommended to get an extra battery anyways.
Allan Rejoso is offline   Reply With Quote
Old May 31st, 2003, 12:24 AM   #20
Outer Circle
So I guess then that only the skin tone feature is missing from the PV-DV953, while this and the fluorescent feature is missing on the PAL MX5 version, along with a slightly different lens. THAT'S not so bad....!
Old May 31st, 2003, 12:43 PM   #21
Received battery 7.2V 1.6Ah Li-ion model CGR-D16 with my Dv-953
Joel
Joel Specter is offline   Reply With Quote
Old June 1st, 2003, 09:07 PM   #22
1600mAh here in Singapore, that's for MX350 and MX500.
I use batteries that looks suspiciously Panasonic, but without the labels. Probably 'over-produced' units! :-) They are listed as 1700mAh and costs 40% of the original Panasonic batteries.
