question for gs100 owners outside Japan - Page 2 at DVinfo.net
Old March 4th, 2004, 12:43 PM   #16
Just remember that "progressive" as used by Panasonic for these cams does not refer to video mode. It's used in reference to stills only and whatever process the cam supposedly applies to ensure higher quality.
Patricia Kim is offline   Reply With Quote
Old March 5th, 2004, 06:05 AM   #17
Thanks, I re-read the manual & I see that.
So ...
Progressive = only photo mode
Normal = video mode (interlaced)
Frame = video mode (30 frames per second - I.E. progressive)
Wide = video mode (16:9 + normal)
Procinema = video mode (16:9 + frame)
Sound about right?
Robert
Robert Sato is offline   Reply With Quote
Old March 5th, 2004, 10:52 AM   #18
sounds about right from what i;ve read, except that you forgot to put in cine-like gamma under pro-cinema mode.
Tavis Shaver is offline   Reply With Quote
Old March 5th, 2004, 05:42 PM   #19
Thanks for pointing that out Tavis.
Weekend has arrived but the Fuji cassettes didn't ... oh well.
Robert
Old March 5th, 2004, 07:13 PM   #20
Outer Circle
How about just buying a couple of Fuji's locally, for the weekend?
Old March 5th, 2004, 10:45 PM   #21
If I can find them locally, of course I'll rather play :-)
Robert
