Possibly the GS200/400/DV953 Killer?? - Page 2 at DVinfo.net
Old May 11th, 2004, 03:54 AM   #16
<<<-- Originally posted by Frank Granovski : 1/4.7" = .212"
1/6" = .166"
I don't see a big difference in size.
Not big but considerable. 28% percent more.
At least a step in the right direction, instead of going down to 1/8".
Carlos
Carlos E. Martinez is offline   Reply With Quote
Old May 11th, 2004, 04:00 AM   #17
Yes 1/4.7 is more bigger and this is good.
Tom E Young is offline   Reply With Quote
Old May 11th, 2004, 04:17 AM   #18
thanks for that tom that was great. i big help i didn't realise till now
Justin
jlboyle
Justin Boyle is offline   Reply With Quote
Old May 11th, 2004, 04:18 AM   #19
Actual specs are at www.sony.jp/products/Consumer/handycam/PRODUCTS/DCR-HC1000/spec.html. 37 mm filter thread size, 780g (w/out battery, I think) which puts it in the weight range of the gs100k. No BT, Frank, so they heard you. Even comes with Mac compatible software. There's an accessories page, also, with several WA lenses and several teleconversions - and a wimpy looking mike with a white (or pale) muff that seems to be connected with the 5.1 surround sound. You can see a reference to VAIO; could be tied to use with Sony's computers.
Question: why isn't this all being discussed in the Sony forum? I saw a few remarks, but remarkably little enthusiasm.
Patricia Kim is offline   Reply With Quote
Old May 11th, 2004, 04:25 AM   #20
i find that most forums apart from this one lack enthusiasm and there is not as much info as there is on this site.
Justin
jlboyle
Old May 11th, 2004, 04:28 AM   #21
heh i think that the 5.1 in this cam will present problems. how do they stop noises like breathing etc being picked up. For those that like to dub also this means that you wont be able to because the channels used for dubbing will be used. another thing is that the best quality recording will be 12db. That probably wont be a problem to most people because they will dub with their computers and most people probably only shoot with 12db instead of 16 or whateva it is. I speak for myself here.
Justin
jlboyle
Old May 11th, 2004, 04:43 AM   #22
Outer Circle
Yes, Boyd is waiting with open arms. :-))
It's good to talk about the competition here, so we can tear them apart. Actually, comparing with the competition will makes us Pana owners stronger. This forum is a cult, after all. :-))
Old May 11th, 2004, 05:08 AM   #23
I hope those aren't pods in the background. (Ooh, that was ghoulish. Sorry.)
Old May 11th, 2004, 05:39 AM   #24
Outer Circle
"Body Snatchers" (?)
Old May 11th, 2004, 06:17 AM   #25
Worse. The cult members in California a few years ago who all got into their "pods" to follow their leader to the great beyond.
Old May 11th, 2004, 06:35 AM   #26
28 percent more is a lot in a small video camcorder. Cults are no good. They suck you in and steal your money. I wish to never belong to any cult. If this place is a cult I do not believe it. I just want good camcorder information from here and Panasonic. I think Panasonic is best. The more I come and read here the more I want one. I have to go now but I will be back tonight.
Old May 11th, 2004, 06:55 AM   #27
28% bigger, but with 24% more pixels...
so there you have it, no difference at all if it's not for the number of pixels.
George Beck is offline   Reply With Quote
Old May 11th, 2004, 09:31 AM   #28
Sony Japan rates minimum lux requirement at 11 lux. I'd bet Sony N.A. would rate it at 6 lux or lower :-))
Allan Rejoso is offline   Reply With Quote
Old May 11th, 2004, 09:34 AM   #29
I'm not too impressed with the look, and am unmoved until I see 16x9, SONY!!!
Michael Struthers
www.buzzdigital.com
Michael Struthers is offline   Reply With Quote
Old May 11th, 2004, 10:10 AM   #30
Yeah, the look leaves something to be desired but more than likely it will have the same high quaility 16:9 mode of the PDX10 since they are both 1/4.7" 3CCD with 1070k pixels each.
Tommy Haupfear is offline   Reply
