homemade mini35 and gs400 - Page 2 at DVinfo.net
Old March 9th, 2005, 09:52 AM   #16
Any chance of posting pics of the adapter?
Patrick Jenkins is offline   Reply With Quote
Old March 13th, 2005, 11:57 PM   #17
Matt,
The pics are perfect (except dust) What screen do you use?
As for editing (the footage flip) are you sure is clean?????????
Did you burn a DVD with the footage and watch it on a big display?
I have tried recently Premiere Pro and I was not happy.
Avid looked clean, but I am not an Avid user :(
Otherwise, is very, very good. Some of the best I have seen.
Dan Diaconu is offline   Reply With Quote
Old March 14th, 2005, 04:51 PM   #18
its been a while since i been here.
i just use a hoya uv filter for the screen. it was ground with 800 aluminum oxide.
the flip in premiere has been giving me trouble recently, it seemed fine before. i'm not entirely sure what is going on with it. i have heard suggestions about de interlacing the footage and that seemed to help.
Matt Ziegeler is offline   Reply With Quote
Old March 14th, 2005, 05:07 PM   #19
What about the frame size?
Is it 24/36mm or less? Lens used? (wide open is...1.?)
I will try de intrerlacing as well.
