Line Level on XLR at DVinfo.net
Old August 23rd, 2003, 07:34 PM   #1
Line Level on XLR
I don't own a DVX100 but may have to connect a MM-1 Mixer to it.
The DVX spec says for the XLR line level : LINE : 0 dBu
My MM-1 Mixer outputs +4dBu.
My question is why is this line level 0 dBu and not +4dBu (Pro standard) or -10dBV (consumer standard) ?
Do I need to insert a pad between the mixer and DVX100 ?
Dany
Dany Nativel is offline   Reply With Quote
Old August 23rd, 2003, 11:07 PM   #2
i guess its to accomodate for the various mics which are available in the filming industry, from shotguns to lavs..
Its also there, i think, to compensate for the internal mic, as they run thru the same line (which is why u can only have one mic selected at once per channel, or 2 seperate mics for each individual channel)
Peter Jefferson is offline   Reply With Quote
Old August 25th, 2003, 10:48 PM   #3
PLEASE ! I need this info for the upcoming week-end.
Peter, I think your comment about various microphones may apply only if you use those XLR connectors with microphone levels (-50dB?). But I think they can also be switched to line levels to carry balanced line levels from a mixer for example. That's why I need to know if they are +4dBu or -10dBV.
Thank you
Dany
Old March 26th, 2004, 10:01 AM   #4
Hi, does anyone know the answer to this by chance? I need to take balanced output from a mixer and put it into the DVX100A. Will it accept balanced line level?
Peter Moore is offline   Reply With Quote
Old March 26th, 2004, 01:53 PM   #5
Dany--you should be fine, it's not that big of a difference. The level adjustment on your mixer will be more than able to compensate. Peter--yes the DVX accepts a balanced line level input.
Barry Schmetter is offline   Reply With Quote
Old March 26th, 2004, 03:43 PM   #6
Thanks Barry!
Old March 27th, 2004, 06:56 AM   #7
i didn't see anyone mention it, on the front of the camera there is a switch to alter the xlr jacks between line and mic level.
make sure you check those switches.
matthew
Matthew de Jongh is offline   Reply With Quote
Old March 27th, 2004, 06:58 AM   #8
Haha, something else that might be good to know. :) Thanks!
