zoom not working on handle at DVinfo.net
Old December 29th, 2003, 06:59 AM   #1
My zoom in/out on my handle is not working for some reason, the record button works fine. Does anyone else have this problem? Do you think its some option that i shut off?? What should i do??
Mike Zorger is offline   Reply With Quote
Old December 29th, 2003, 11:41 AM   #2
Are you on Manual Servo?
John Hudson is offline   Reply With Quote
Old December 29th, 2003, 11:46 AM   #3
Space Hipster
There is also an option in the menu (sorry, don't have a camera right now) to switch zoom controls and there is a both option.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old December 29th, 2003, 01:16 PM   #4
hmm, if someone knows what this option is called could you please list it. thanks.
Old December 29th, 2003, 02:39 PM   #5
Is your camera set to Manual or Servo ?
Or
Go to Camera setup and then SW Mode.
Old December 29th, 2003, 10:19 PM   #6
did you accidentally flip the switch on the right side of the handle that controls how the zoom operates?
Brian Young - Los Angeles - www.FlacaProductions.com
F800, F5, FS7, A7s
Brian T. Young is offline   Reply With Quote
Old December 30th, 2003, 09:08 AM   #7
ok well i fixed it last night, but i still dont understand how it stopped working, i never have gone into the menu i was in last night for any reason in the past month. kind of stange. oh well it works now, thanks guys.
Old December 30th, 2003, 10:19 PM   #8
DVX User
This actually happend for me.. but it stopped working for almost a month, then started working again. I think it may of been something to do with the speed switch, but I will never know.
Jarred Land is offline   Reply With Quote
Old January 1st, 2004, 10:06 PM   #9
Your talking about the handle up top, right? The default setting on speed 2 is no speed - i.e. the zoom does not work on the handle in position 2. Try 1 or 3. It's in the manual.
Justin
What's this button for?
Justin Chenier is offline   Reply
