dvx audio volume at DVinfo.net
Old June 21st, 2004, 01:11 AM   #1
dvx audio volume
Has anyone had problems with the recorded audio level on the DVX. I just bought this camera and the audio is very low. The volume bars on the lcd show 75 to 100 percent but the playback is way to low. After download to FCX the exact volume is present. I would rather not have to correct this problem in post. Any advice. Is this normal for this camera??
Hugh Dorigo is offline   Reply With Quote
Old June 24th, 2004, 08:58 AM   #2
Get another microphone and don't use the in-camera mic. In plain English "It sucks!"
Ernest L. Acosta, Jr.
President
Garage At Large Productions
P.O. Box 42
Times Square Station
New York, NY 10108
Ernest Acosta is offline   Reply With Quote
Old June 25th, 2004, 12:12 PM   #3
I just got a DVC30 and I'm having the same problem. On auto mike level, the audio is too low. I have to push it manually to near 100% to get satisfactory levels.
Ernest, do you have a suggestion for a reasonably priced general purpose mike? I'd like to get the XLR adapter and go that route eventually.
Eric Woodfin is offline   Reply With Quote
Old June 25th, 2004, 02:54 PM   #4
i have the same problem. in truth, EVERYONE does. go into your menu option and change recordning mode from -50 to -60
www.astrosecretfilms.com
real independent
Michael Summers is offline   Reply
