dvx100 film look mode vs. XL1s ? at DVinfo.net
Old December 11th, 2002, 04:38 PM   #1
gateway1
Posts: n/a
Who here has seen both and what do you think? I've heard that the dvx is much better
Old December 14th, 2002, 09:22 PM   #2
Outer Circle
What's the film look mode? 30P? 24P?
The XL1 doesn't have progressive scan CCDs. It uses a different method for capturing progressive. The DVX100 uses progressive scan CCDs. In 30P, both capture by skipping every 2nd frame, and this frame capture is then interlaced for VHS and S-video output. The big difference is that the DVX captures then interlaces, whereas the XL1 captures 2 fields at the same time (or almost the same time) and then uses interplolation to create a frame.
Frank Granovski is offline   Reply
