Underwater Housing? at DVinfo.net
Old May 15th, 2003, 08:43 PM   #1
Underwater Housing?
Does anyone know where I may be able to buy an underwater housing / splash bag for shallow (swimming pool depth) filming using my Panasonic AG DVX 100?
Cheers!
Pepi Singh Khara
www.frederickfilms.com
Pepi Singh Khara is offline
Old May 20th, 2003, 01:10 PM   #2
RED Code Chef
I did a quick google search and came up with the following:
http://www.ewa-marine.de/English/Camcorder/e-V1000.htm (at the bottom of the page)
Could not find much else...
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old May 20th, 2003, 07:43 PM   #3
Try contacting Ikelite as they might have one on the way.
Adrian Douglas is offline
Old May 20th, 2003, 09:55 PM   #4
Thanks Guys!!!
Tot Ziens!
Old May 21st, 2003, 08:26 AM   #5
Thanks for the info. I just spoke to EWA Marine in Germany and they put me in touch with B&H. I've just ended up purchasing the underwater housing, 72mm adapter, lead weights from them for my AG DVX100.......
Can't wait to get and include some underwater shots for our almost finished feature "Far from India" (www.frederickfilms.com).
Thanks again to both of you.
Pepi.
Old May 30th, 2003, 06:47 PM   #6
I ordered the ewa-marine for my GL-1 a couple of years ago, but sent it back. Not because it didn't work - I didn't try it. It just looked a bit too flimsy to be dunking my camera in. I took my gear rafting down the Colorado River in the Grand Canyon. I wasn't looking for something to dive deep in. Mostly I wanted to strap the camera to the fore of the raft while going through rapids. I ended up with a Surf ACE Scubacam DV. Check out
http://www.16x9inc.com/cgibin/store/...gno=SCU-VX1000
It kept the camera dry and away from the sand and dust. It's pretty hefty and it made me feel more secure to see my gear taking a major splashing in the scubacam. My only difficulty was seeing the monitor in harsh light. You plug your camera into a small monitor that is visible through the back circular port. I had to huddle close and shade the back to see the monitor. But I don't think you'd have any trouble if you were looking at it underwater. I also plan on taking the scubacam with my GL-2 to sea kayak in Alaska.
LS-A
Lisa Strong is offline
Old May 30th, 2003, 07:19 PM   #7
DVX User
I would suggest the equinox pro pak 8... its the only housing thats so solid you wont worry...
If it looks like a bag you will be praying to god every time it gets wet.
Jarred Land is offline
Old June 12th, 2003, 10:12 PM   #8
ewa marine
I just won 1st prize with my short film "Sweet Dreams" (8 minutes long). It has an underwater shot where we look up at the actress from the sink as she washes her face in a sink full of water...... done with the EWA MARINE........ it worked like a charm....... was done in a bath tub to simulate a sink and the shot cut into place very well and looked awesome.
You can see the entire film on www.frederickfilms.com/sweetdreams.htm
Would certainly recommend this simple housing for this camera.
